Author Topic: AMD Crimson ReLive Edition 17.4.3  (Read 2193 times)
« on: April 18, 2017, 06:40:50 PM »
Radeon Software Crimson ReLive Edition 17.4.3 Highlights
    • Support for Windows®10 Creators Update.
    • Support for Radeon RX 580 Series Graphics.
    • Support for Radeon RX 570 Series Graphics.
Known Issues
    • Radeon WattMan may fail to apply settings on some Radeon R9 390 series graphics products.
    • Radeon Settings may crash on switching Windows® user after toggling AMD CrossFire™ technology mode.
    • A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background.
    • Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue.
Known Issues for Radeon ReLive
    • The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues.
    • Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products.
    • Radeon ReLive may intermittently fail to work after performing task switches of applications. A work around is to disable and then enable the feature in Radeon Software.
    • Radeon ReLive may exhibit corruption in recordings when capturing Microsoft Office applications.
    • Radeon ReLive may experience recording or streaming issues when task switching using ALT+TAB.
