Author Topic: Unity 2017.1.0b1  (Read 2391 times)
Unity 2017.1.0b1
« on: April 17, 2017, 04:05:15 PM »
2017.1.0b1 Release Notes (new since a6)
 Known Issues
  • Animation: Reading from Animator.rootPosition and Animator.rootRotation during OnAnimatorMove gives wrong results. Use Animator.deltaPosition and Animator.deltaRotation instead. (899049)
  • Audio: AudioSource attached to VideoPlayer produces choppy sound when playing certain mp4 files with VideoPlayer created from script (895458)
  • Editor: "The system cannot find file specified" error while opening the project for the first time. Deleting Library folder resolves the issue. (895343)
  • Editor: Editor crashes on attempt to open some 5.5 compatible audio projects. (880653)
  • Editor: Text in Editor becomes red after dismissing EditorUtility.DisplayDialog() popups. (886650)
  • Editor: Unity crashes when playing a scene with maximized game view (894572)
  • Graphics: "Assertion failed on expression: 'translated != kInvalidEnum'" error is spammed in the console when selecting an Image file (883459)
  • Graphics: Debug GFX overlay is drawn on top of objects. (851379)
  • iOS: OnGUI fails to draw any elements on iOS (883482)
  • Physics: Crash when reverting prefab which had Rigidbody and Joint deleted, and then undoing the revert. (870498)
  • VR: Rendering problems on Pixel Daydream when using 4x or 8x MSAA with single-pass stereo.  This is due to driver issues, so the problem will be addressed via a driver update, independently of Unity releases. (-)
  • Collab: In-Progress. In-Progress allows developers using Unity Collaborate to see who else on their team has made local changes to a Scene or Prefab before those changes have been published.
  • Graphics: Added LineUtility class and 'LineRenderer.Simply' function. Optimize your lines and curves by using the LineUtility to create a simplified version with a similar shape.
  • Graphics: Added memoryless mode to RenderTexture, accessed through new property RenderTexture.memorylessMode.
  • Playables: Timeline Editor and Runtime API. A tool for sequencing animation, scripts and audio.
  • Animation: Fixed adding State/StateMachines with invalid names. (882122)
  • Editor: Fixed a crash in Editor caused by null Handles. Graphics.DrawMeshNow will now throw an exception if the mesh is null. (893112)
  • Particles: Removing a ParticleSystem on a GameObject that has a component with RequireComponent(Renderer) is now correctly prevented. (888048)
  • Particles: Size over lifetime now correctly affects collider size, and sub-emitter inheritance. (792289)
The following are changes and fixes to 2017.1.0 features and regressions... Fixes
  • Android: Fixed reading assets from OBB (ApplicationPath) (891864)
  • Android: Fixed WebCamTexture crash with denied permissions (877837)
  • Android: Gradle - Check the signing key before the build starts (889076)
  • Android: SoftInput - Fixed input field hidden under keyboard when translucent flag is set
  • Animation: Fixed animation clip range not updating after undoing 'Add Key' operation. (892337)
  • Animation: Fixed disabling GameObject not resetting StateMachine (894062)
  • Animation: Fixed error message when changing animation type from None to Humanoid in model importer. (888414)
  • Animation: Fixed error message when entering playmode after renaming an AnimatorParameter when previewing a BlendTree. (891547)
  • Animation: Fixed IK on Feet not working when interrupting transitions. (892043)
  • Animation: Fixed NullReferenceException when clicking in empty Animator window. (891126)
  • Animation: Fixed NullReferenceException when entering newly created BlendTree in graph. (891128)
  • Animation: Fixed OnAnimatorIK not being fired in editor mode. (894061)
  • Animation: Fixed performance regression when destroying many game objects with an Animator. (889109)
  • Build Pipeline: Building many AssetBundles should no longer spend a long time updating the BuildReport between each bundle (849376)
  • Build Pipeline: Fixed SetScriptingDefineSymbolsForGroup() failing for BuildTargetGroup.Switch (863992)
  • Editor: Fixed 'Build and Run' attempts to push a build to device even if error (during the build) was encountered (894074)
  • Editor: Fixed GUI related Asserts when connected to an active VCS provider. (895453)
  • Graphics: Fix SceneView GUI elements being very bright when HDR and Linear mode are enabled. (878724)
  • Graphics: Fixed light rendering when a non-full screen viewport Camera renders to a texture. (880293)
  • IL2CPP: Allow more deeply nested generic recursion for method metadata. Throw an managed exception when the recursion is too deep. (889446)
  • IL2CPP: Fix memory snapshot profiler not showing multidimensional arrays (888796)
  • IL2CPP: Fixed marshaling of System.Uri to Windows.Foundation.Uri and back in Windows Runtime interop scenarios (887036)
  • Shaders: Fixed a subtle metal shader generation bug in bit field insert operations.
  • Windows: Fixed a crash that occurred in Metro apps when minimized/exiting on Windows RS1/RS2 (885964)
Unity 2017.1.0b2
« Reply #1 on: April 26, 2017, 10:22:50 PM »
The beta 2 version for 2017.1 is now available.
 As always, installers and release notes available at:
 Current Documentation links:
 Scripting Reference
 User Manual
 Upgrade guide
 (Note that online documentation is updated at a different rate from the release)
 Please remember to back up your projects before opening them in a beta build!
