Author Topic: GPU Caps Viewer 1.33.1 released  (Read 4313 times)
« on: March 06, 2017, 11:55:36 AM »
A new version of GPU Caps Viewer is available. The version 1.33.1.0 is a maintenance release that fixes a bug in the Vulkan initialization routine:
Download:
http://www.geeks3d.com/20170302/gpu-caps-viewer-1-33-0-opengl-vulkan-opencl-cuda-information-utility/
Re: GPU Caps Viewer 1.33.1 released
« Reply #1 on: March 06, 2017, 05:53:00 PM »
Intel GPUs render nothing.
Screenshot from Broadwell with modified driver build 4473
But i have also word from Gen9 user with recent driver build 4612
17:48:50 | 381 >> [SGX] - [Vulkan] - GPU name: Intel(R) HD Graphics 5500
17:48:50 | 382 >> [SGX] - [Vulkan] - DeviceID: 8086-9CC3
17:48:50 | 383 >> [SGX] - [Vulkan] - Raw driver version: 65538
17:48:50 | 384 >> [SGX] - [Vulkan] - Vulkan API version: 1.0.0
17:48:50 | 385 >> [SGX] - [Vulkan] - Device type: VK_PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
17:48:50 | 386 >> [SGX] - [Vulkan] - Memory heap count: 2
17:48:50 | 387 >> [SGX] - [Vulkan]         heap 0 - size: 1040 MB
17:48:50 | 388 >> [SGX] - [Vulkan]         heap 1 - size: 1040 MB
17:48:50 | 389 >> [SGX] - [Vulkan] - Device extensions: 2
17:48:50 | 390 >> [SGX] - [Vulkan]         1/ VK_KHR_swapchain (spec version: 68)
17:48:50 | 391 >> [SGX] - [Vulkan]         2/ VK_KHR_sampler_mirror_clamp_to_edge (spec version: 1)
17:48:50 | 392 >> [SGX] - [Vulkan] GPU 0 initialized ok
17:48:50 | 393 >> [SGX] - Vulkan renderer initialized OK.
17:48:50 | 394 >> [SGX] - Vulkan GPU 0: 207311536
17:48:50 | 395 >> [SGX] - [Lua] lfs library loaded ok
17:48:50 | 396 >> [SGX] - [Lua] LuaSockect library loaded ok
17:48:50 | 397 >> [SGX] - [Lua] mime (LuaSockect) library loaded ok
17:48:50 | 398 >> [SGX] - [Lua] LuaGL library loaded ok
17:48:50 | 399 >> [SGX] - [Vulkan] texture texture_332 successfully loaded (size=512x512)
17:48:50 | 400 >> [SGX] - [Vulkan] texture texture_341 successfully loaded (size=512x512)
17:48:50 | 401 >> [SGX] - [Vulkan] Vertex shader module creation ok (GPU program: kx_font_prog).
17:48:50 | 402 >> [SGX] - [Vulkan] Pixel shader module creation ok (GPU program: kx_font_prog).
17:48:50 | 403 >> [SGX] - [Vulkan] descriptorset successfully built
17:48:50 | 404 >> [SGX] - [Vulkan] descriptorset successfully built
17:48:50 | 405 >> [SGX] - [Vulkan] pipeline object pso_font_p successfully created.
17:48:50 | 406 >> [SGX] - [Vulkan] pipeline object pso_font_h1 successfully created.
17:48:50 | 407 >> [SGX] - [Vulkan] texture C:\Program Files (x86)\Geeks3D\GPU_Caps_Viewer\gxldemos/vk-shadertoy/../framework/data/textures/vk.png successfully loaded (size=300x80)
17:48:50 | 408 >> [SGX] - [Vulkan] Vertex shader module creation ok (GPU program: kx_texture_prog).
17:48:50 | 409 >> [SGX] - [Vulkan] Pixel shader module creation ok (GPU program: kx_texture_prog).
17:48:50 | 410 >> [SGX] - [Vulkan] descriptorset successfully built
17:48:50 | 411 >> [SGX] - [Vulkan] pipeline object kx_pso_tex successfully created.
17:48:50 | 412 >> [SGX] - [Vulkan] Vertex shader module creation ok (GPU program: shadertoy_shader).
17:48:50 | 413 >> [SGX] - [Vulkan] Pixel shader module creation ok (GPU program: shadertoy_shader).
17:48:50 | 414 >> [SGX] - [Vulkan] descriptorset successfully built
17:48:50 | 415 >> [SGX] - [Vulkan] pipeline object pso01 successfully created.
17:48:50 | 416 >> [SGX] - Demo initialized OK.
17:50:13 | 417 >> [SGX] - [Vulkan] Texture (texture_332 / 332) unloaded from GPU memory
17:50:13 | 418 >> [SGX] - [Vulkan] Texture (texture_341 / 341) unloaded from GPU memory
17:50:13 | 419 >> [SGX] - [Vulkan] Texture (C:\Program Files (x86)\Geeks3D\GPU_Caps_Viewer\gxldemos/vk-shadertoy/../framework/data/textures/vk.png / 360) unloaded from GPU memory
17:50:13 | 420 >> [SGX] - Demo terminated OK.
17:53:08 | 421 >> GPU Caps Viewer 1.33.1.0 shutdown...
17:53:08 | 422 >> GPU Caps Viewer shutdown ok.
« Last Edit: March 06, 2017, 05:54:55 PM by Stefan »
