Author Topic: GPU Caps Viewer 1.32.0.1 Vulkan demos crash on RX 480  (Read 3702 times)
kode54
« on: February 07, 2017, 05:45:16 AM »
Running with the Crimson ReLive drivers, version 17.1.1 non-WHQL, all of the Vulkan demos immediately crash in vulkan-1.dll.
E: Same crash with version 17.1.2 non-WHQL.
« Last Edit: February 07, 2017, 06:13:57 AM by kode54 »
Re: GPU Caps Viewer 1.32.0.1 Vulkan demos crash on RX 480
« Reply #1 on: February 07, 2017, 11:21:03 AM »
thanks for the report. I will test the Vulkan demos with a RX 470 asap!
« Reply #2 on: February 07, 2017, 05:32:52 PM »
atm the demos crash on any rig, e.g. on my GeForce 840M
some Intel Gen9 iGPU users told me the same
memory offsets from Vulkan SDK 1.039.1
'GpuCapsViewer.exe' (Win32): Loaded 'C:\WINDOWS\SysWOW64\vulkan-1.dll'. Module was built without symbols.
The thread 0x31c0 has exited with code 0 (0x0).
Unhandled exception at 0x5500C5F7 (vulkan-1.dll) in GpuCapsViewer.exe: 0xC0000005: Access violation reading location 0x6425202F.
>    vulkan-1.dll!5500c5f7()    Unknown
     [Frames below may be incorrect and/or missing, no symbols loaded for vulkan-1.dll]
     vulkan-1.dll!5500ca9c()    Unknown
     plugin_gxc_vulkan_x32.dll!558e3de6()    Unknown
     plugin_gxc_vulkan_x32.dll!558e3a9d()    Unknown
     gxl_x32.dll!582230eb()    Unknown
     gxl_x32.dll!581e78ad()    Unknown
     gxl_x32.dll!581fa3c7()    Unknown
     sgx_x32.dll!58e71d24()    Unknown
     sgx_x32.dll!58e7215e()    Unknown
     GpuCapsViewer.exe!00b432ee()    Unknown
« Reply #3 on: February 07, 2017, 07:02:08 PM »
Ok, I think recent drivers from NVIDIA and AMD come with serious changes in Vulkan API that can explain the crashes. I prefer that. I have to dive in my Vulkan code (GeeXLab) and hunt the bug! I will do this asap.
