Author Topic: AMD Crimson ReLive Edition 16.12.2 WHQL  (Read 2093 times)
« on: January 09, 2017, 08:41:54 PM »
 Radeon Software Crimson ReLive Edition 16.12.2 Highlights
 Fixed Issues
    • AMD FreeSync™ technology may experience performance issues with Borderless Fullscreen application support when a secondary display is attached and has dynamic content running such as video playback in a web browser or if other applications or game launchers are running on the primary screen in the background. A workaround if this issue is experienced is to minimize all other running applications that are on the primary desktop display or on non-primary extended displays.
    • Radeon ReLive may fail to install during installation on some system configurations.
    • Battlefield™1 may experience flashing or corruption when running in Multi GPU with Radeon RX 400 series.
    • Instant Replay fails to enable itself after it has been turned off due to content protection.
    • Radeon Settings may not load on system boot for some system configurations.
    • Fixed some errors in translations for Radeon Settings and Radeon ReLive.
    • Audio recorded by Radeon ReLive may sometimes exhibit slow motion when played back.
    • Radeon ReLive may experience recording issues or issues toggling the Overlay/Toolbar when Frame Rate Target Control is enabled. Users are suggested to disable Frame Rate Target Control when using Radeon ReLive.
    • Mouse cursor may stutter in recorded video when there is limited on screen activity outside of minor mouse movement.
    • In AMD Multi GPU configurations the secondary graphics product will exit the low power state when Radeon ReLive is enabled.
    • Radeon ReLive may sometimes not be able to take screenshots of secondary displays.
    • Chromium may fail to utilize hybrid decode for VP9 content.
    • DOTA™2 may experience game corruption when performing a task switch while recording with Radeon ReLive in AMD Multi GPU configurations.
    • Radeon ReLive Overlay/Toolbar will not launch or Record when running League of Legends™ in Administrator Mode and Windowed Borderless Fullscreen.
    • Long ping times may be experienced with some WiFi adapters.
