Author Topic: GPU Caps Viewer 1.31.0 released  (Read 2723 times)
« on: August 26, 2016, 10:45:41 AM »
GPU Caps Viewer 1.31.1.0 released
« Reply #1 on: September 09, 2016, 12:28:09 PM »
Re: GPU Caps Viewer 1.31.0 released
« Reply #2 on: September 09, 2016, 07:14:35 PM »
How to use the new command line option (/exp_full_filename) to export a report file in a specific folder:
GpuCapsViewer.exe /exp_txt_report /exp_full_filename="C:/tmp/gpucapsviewer_report.txt"
or
GpuCapsViewer.exe /exp_xml_report /exp_full_filename="C:/tmp/gpucapsviewer_report.xml"
