Author Topic: Vulkan API specifications 1.0.4 released  (Read 75453 times)
Vulkan API specifications 1.0.47 released
« Reply #20 on: April 11, 2017, 03:17:11 PM »
  * Bump API patch number and header version number to 47 for this update.
Github Issues:
  * Allow <<synchronization-pipeline-barriers-subpass-self-dependencies,
    self-dependencies>> (also described for slink:VkSubpassDependency) to
    have earlier stages depend on later stages if all stages are
    framebuffer-space (public issue 125).
  * Clarify when pipeline state structures are ignored in the
    slink:VkGraphicsPipelineCreateInfo strucure, when the tessellation
    structure must be valid, and remove 'if `NULL`' descriptions from the
    valid usage statements (public issue 445).
  * Remove the obsolete "validextensionstructs" attribute for
    flink:VkPresentRegionsKHR. This caused a pname:pNext valid usage
    statement to be generated which wasn't consistent with what is stated in
    the spec (public issue 481).
Internal Issues:
  * Clarify facingness of non-polygon fragments for slink:VkStencilOpState
    and in the code:FrontFacing <<interfaces-builtin-variables,built-in
    variable description>>. Define 'facingness' of a fragment as a distinct
    term from facingness of a polygon (internal issue 662).
  * Clarify that the texture compression features (e.g.
    pname:textureCompressionBC) means that all formats of that type
    (<<features-features-textureCompressionASTC_LDR,ASTC>>,
    <<features-features-textureCompressionETC2,ETC2>>,
    <<features-features-textureCompressionBC,BC>>) are supported, and that
    support for individual formats may: queried separately (internal issue
    663).
  * Clarify in the valid usage for slink:VkBindImageMemoryInfoKHX that each
    SFR rectangle must be a multiple of the sparse block size for each
    aspect, e.g. in a depth/stencil image using separate depth/stencil
    planes (internal issue 721).
  * Re-remove KHX variants of KHR structure types after promotion (internal
    issue 762).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/0285e9c97749eb0db63843b76c6202e14996b5aa
Vulkan API specifications 1.0.48 released
« Reply #21 on: April 16, 2017, 10:06:41 AM »
* Bump API patch number and header version number to 48 for this update.
Github Issues:
Internal Issues:
  * Add missing VU statements for flink:vkUpdateDescriptorSets (internal
    issue 333).
  * Correct swapped ifdef/ifndef blocks for `VK_KHR_maintenance1` extension
    (internal issue 776).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/757a1232e6541db17585d1f59a17dfdaa272c100
Vulkan API specifications 1.0.49 released
« Reply #22 on: May 13, 2017, 05:55:05 AM »
Change log for May 12, 2017 Vulkan 1.0.49 spec update:
  * Bump API patch number and header version number to 49 for this update.
Github Issues:
  * Modify reference page extraction script to make internal links to spec
    anchors refer to the core specification instead of being dangling links
    (public issue 455).
  * Fix GL_KHR_vulkan_glsl typo and add a nor-normative mapping to the newly
    published StorageBuffer class (public issue 466).
  * Both flink:vkEnumerateInstanceExtensionProperties and
    flink:vkEnumerateDeviceExtensionProperties return
    ename:VK_ERROR_LAYER_NOT_PRESENT, which covers the error case of an
    application providing a layer name that wasn't returned by
    ftext:vkEnumerate{Instance|Device}LayerProperties (public issue 487).
  * The specification for flink:VkApplicationInfo::apiVersion says that the
    driver must return ename:VK_ERROR_INCOMPATIBLE_DRIVER in the case that
    pname:apiVersion specifies a non-supported version. That means that the
    valid usage should not also state that, and so the VU statement is
    removed. The VU had language about "`an effective substitute`" that
    would have been lost, and so it was moved to the pname:apiVersion
    description (public issue 488).
Internal Issues:
  * Modify implicit validity generator script to assign asciidoc anchors to
    all valid usage statements it generates, and reflow.py script to insert
    Valid Usage ID (VUID) tags into the specification source files for
    explicit valid usage statements. This has no semantic effects on the
    specification, but will support the validation layer's detection of
    valid usage violations and allow it to link into the corresponding part
    of the specification (internal issue 583).
  * Assign VUID tags to all explicit VU statements and document
    the process and tag format in the style guide (internal issue 583).
  * Clarify the rules of whether to structure new functionality as instance
    extensions, device extensions, or both in the
    <<extended-functionality-instance-extensions-and-devices, Instance
    Extensions and Device Extensions>> section (internal issue 749).
  * Require that SPIR-V run-time arrays are only used with the
    code:BufferBlock decoration (internal issue 750).
  * Fix implicit and explicit valid usage statements for
    slink:VkWriteDescriptorSet::pname:dstSet (internal issue 767)
  * Fix SPIR-V code sample for ename:VK_DESCRIPTOR_TYPE_UNIFORM_TEXEL_BUFFER
    in the <<descriptorsets-uniformtexelbuffer, Uniform Texel Buffer>>
    section (internal issue 770).
  * Clarify that disabling depth testing also disables depth writes in the
    <<fragops-ds-state, Depth and Stencil Operations>> section (internal
    issue 775).
  * flink:VkDescriptorImageInfo::pname:imageLayout must match the actual
    imageLayout at the time the image is accessed. This was in the spec
    text, but needed an associated valid usage statement.
  * Note that only 32-bit atomic operations are supported in the
    <<spirvenv-module-validation, Validation Rules within a Module>>
    section.
  * Note that code:UniformConstant variables must not have initializers in
    the <<spirvenv-module-validation, Validation Rules within a Module>>
    section.
  * Add a new elink:VkObjectType enumeration to the core API, promoted from
    elink:VkDebugObjectTypeEXT, since it is used for much more than just the
    debug_report extension.
New Extensions:
  * `VK_KHR_get_surface_capabilities2`
  * `VK_KHR_shared_presentable_image`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/685295031d092db5417a5254e4f8b3e8024214cf
Vulkan API specifications 1.0.50 released
« Reply #23 on: May 21, 2017, 08:39:55 AM »
Change log for May 20, 2017 Vulkan 1.0.50 spec update:
  * Bump API patch number and header version number to 50 for this update.
Github Issues:
  * Fix numerous minor issues with the VK_EXT_debug_report extension (public
    issues 478, 483, 486, 489, 490).
Internal Issues:
  * Update flink:vkAllocateDescriptorSets to specify conditions under which
    to return ename:VK_ERROR_FRAGMENTED_POOL or
    ename:VK_ERROR_OUT_OF_POOL_MEMORY instead of
    out-of-host/out-of-device-memory, and improve the
    <<fundamentals-errorcodes, description of those errors (internal issue
    654).
  * Add a NOTE documenting that flink:vkAcquireNextImageKHR can only signal
    a single semaphore, and how to deal with that when multiple physical
    devices in a logical device need to wait on it (internal issue 730).
  * Improve description of pname:pNext chains of
    slink:VkPhysicalDeviceImageFormatInfo2KHR and
    slink:VkImageFormatProperties2KHR (internal issue 814).
  * Clean up math markup issues in the <<textures, Image Operations>>
    chapter (internal issue 818).
  * Update validusage target to use more robust code for preprocessing, by
    making direct use of Asciidoctor's preprocessor. Added uniqueItems check
    to JSON vu schema and add clean_validusage target (internal issue 826).
  * Update style guide to prohibit writing non-self-contained (on a single
    bullet point) Valid Usage statements, and modify offending Valid Usage
    statements in the Specification to match, to assist with automatic
    extraction for the validation layers (internal issue 828).
  * Add ename:VK_VALIDATION_CHECK_SHADERS_EXT to elink:VkValidationCheckEXT
    of the `VK_EXT_validation_flags` extension, to selectively disable
    shader validation.
  * Remove duplicate valid usage statement for slink:VkImageMemoryBarrier.
  * Modify reflow.py script to place VUID tag anchors standalone on a line
    following their corresponding bullet point, and reflow the spec text
    accordingly (this had been pending since the initial tag deployment).
New Extensions:
  * `VK_AMD_texture_gather_bias_lod`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/cebb71d06253ee37909f281eed93ad7243530fce
Vulkan API specifications 1.0.51 released
« Reply #24 on: June 05, 2017, 11:26:16 AM »
Change log for June 4, 2017 Vulkan 1.0.51 spec update:
  * Bump API patch number and header version number to 51 for this update.
Github Issues:
  * Add Valid Usage statement to flink:vkCmdResolveImage to require that
    source and destination image formats match (public issue 492).
  * Specify that a code:char* parameter must: be a valid null-terminated
    string in the <<fundamentals-implicit-validity, implicit valid usage>>
    section (public issue 494).
  * Removed unnecessary VU for slink:VkPhysicalDeviceFeatures which is
    covered by ename:VK_ERROR_FEATURE_NOT_PRESENT already (public issue
    496).
  * Clarify valid usage of pname:pQueueFamilyIndices in
    slink:VkBufferCreateInfo, slink:VkImageCreateInfo, and
    slink:VkSwapchainCreateInfoKHR (public issue 501).
  * Document that dependencies of enabled extensions must also be enabled in
    the <<extended-functionality-extensions-dependencies, Extension
    Dependencies>> section (public issue 507).
Internal Issues:
  * Change slink:VkMappedMemoryRange valid usage to allow pname:offset +
    pname:size == size of the allocation. Also, if ename:VK_WHOLE_SIZE is
    used, require the end of the mapping to be aligned to a multiple of
    pname:nonCoherentAtomSize (internal issue 611).
  * Add issue to `VK_KHR_win32_surface` about reusing window objects from a
    different graphics API or Vulkan ICD (internal issue 639).
  * Require locations on user in/out in `GL_KHR_vulkan_glsl` (internal issue
    783).
  * Added version info to the json validation output, and updated the schema
    to match (internal issue 838).
  * Restructure enumerated type descriptions separately from the command or
    structure they are used in, allowing better reference page generation
    (internal issue 841).
  * Re-sort extension appendices to be in alphabetical order within each
    author ID section.
  * Fix enum naming and clarify behavior for
    `VK_NVX_device_generated_commands` extension.
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/1d67e47f1464d5f5e654a405e9a91c7d5441bbb6
« Last Edit: June 05, 2017, 02:10:24 PM by JeGX »
Vulkan API specifications 1.0.53 released
« Reply #25 on: June 29, 2017, 07:09:30 PM »
Change log for June 24, 2017 Vulkan 1.0.53 spec update:
  * Bump API patch number and header version number to 53 for this update.
Github Issues:
Internal Issues:
  * Clarify mappings of coordinates for mutable, compatible image views in
    slink:VkImageViewCreateInfo (internal issue 815).
  * Make ename:VK_BIND_SFR_BIT require a logical device with multiple
    physical devices, so that standard sparse image block dimensions are
    only required on systems that support multi-GPU (internal issue 835).
  * Convert all files from use of // refBegin .. // refEnd comments to
    delimit ref pages, to use of open blocks, and update style guide
    accordingly (internal issue 839).
  * Add valid usage for slink:VkWriteDescriptorSet when performing updates
    to a ename:VK_STORAGE_IMAGE descriptor with layout
    ename:VK_IMAGE_LAYOUT_GENERAL.
  * Add a hack to the validity generator script to support an odd
    interaction between flink:vkCmdFillBuffer and an extension (internal
    issue 853).
  * Remove redundant text describing slink:VkBufferCreateInfo::pname:usage,
    which was already covered by implicit valid usage (internal issue 854).
  * Update implicit validity generator script to properly handle the
    pname:sType and pname:pNext members of "returnedonly" structures
    (internal issue 874).
  * Note that slink:VkApplicationInfo::pname:pApplicationName &
    slink:VkApplicationInfo::pname:pEngineName are optional, and add missing
    implicit valid usage statements for flink:vkDestroyInstance.
  * Added missing valid usage for flink:vkCmdWriteTimestamp to require a
    timestamp query pool.
  * Simplify and/or split "`non-atomic`" valid usage statements.
New Extensions:
  * `VK_AMD_gpu_shader_int16`
  * `VK_EXT_blend_operation_advanced`
  * `VK_EXT_sampler_filter_minmax`
  * `VK_NV_framebuffer_mixed_samples`
Note: the 1.0.52 spec wasn't published on github, so the 1.0.53 release
combines both change sets.
Change log for June 13, 2017 Vulkan 1.0.52 spec update:
  * Bump API patch number and header version number to 52 for this update.
Github Issues:
Internal Issues:
  * Clarify behavior when non-coherent memory has
    <<memory-device-unmap-does-not-flush, not been flushed before being
    unmapped>> (internal issue 819).
  * Fix description of code:WorkgroupSize builtin to note it decorates an
    object, not a variable (internal issue 836).
  * Fix asciidoc attributes so that trailing '{plus}' symbols in [eq] style
    equations are rendered properly (internal issue 845).
  * Add language to the "`Extension Handles, Objects, Enums, and Typedefs`"
    section of the Procedures and Conventions document stating that any new
    handle type requires a corresponding entry in the elink:VkObjectType
    enumerated type (internal issue 856).
  * Update style guide to use slink macro for Vulkan handle type names, and
    define narrow conditions under which to use the *name and *text macros
    instead of *link (internal issue 886).
  * Add a dependency of the <<VK_KHX_device_group,VK_KHX_device_group>>
    extension on VK_KHX_device_group_creation to +vk.xml+ and the extension
    appendix.
  * Change the copyright on Vulkan specification asciidoc *source* files to
    CC-BY 4.0, and update the proprietary Khronos copyright applied to the
    generated *output* formats (internal issue 327). This enables broader
    re-use and modification of the Vulkan specification sources, while not
    affecting the Reciprocal IP License between Vulkan Adopters and Working
    Group Members.
New Extensions:
  * `VK_NV_fill_rectangle`
  * `VK_NV_fragment_coverage_to_color`
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/b9e9296cd86d5f83ff33619831ca68d0a7be8457
Vulkan API specifications 1.0.54 released
« Reply #26 on: July 13, 2017, 08:29:33 PM »
Change log for July 13, 2017 Vulkan 1.0.54 spec update:
  * Bump API patch number and header version number to 54 for this update.
Github Issues:
Internal Issues:
  * Fix tessellation domain to have an upper-left origin in the
    <<img-tessellation-topology-ul, tessellation toplogy image>> and related
    language. CTS and all implementations were already doing this, it was
    just a documentation bug that it was flipped to lower-left (internal
    issue 603).
  * Add a section to the style guide describing how VUID tags are changed
    and removed when the corresponding Valid Usage statements are modified
    (internal issue 829).
  * Add explicit Valid Usage statement to
    slink:VkPipelineDynamicStateCreateInfo to require that members of
    pname:pDynamicStates must be unique (internal issue 851).
New Extensions:
  * `VK_KHR_16bit_storage`
  * `VK_KHR_dedicated_allocation`
  * `VK_KHR_external_fence`
  * `VK_KHR_external_fence_capabilities`
  * `VK_KHR_external_fence_fd`
  * `VK_KHR_external_fence_win32`
  * `VK_KHR_get_memory_requirements2`
  * `VK_KHR_storage_buffer_storage_class`
  * `VK_KHR_variable_pointers`
Extensions Promoted From KHX To KHR Status:
  * `VK_KHR_external_memory`
  * `VK_KHR_external_memory_capabilities`
  * `VK_KHR_external_memory_fd`
  * `VK_KHR_external_memory_win32`
  * `VK_KHR_external_semaphore`
  * `VK_KHR_external_semaphore_capabilities`
  * `VK_KHR_external_semaphore_fd`
  * `VK_KHR_external_semaphore_win32`
  * `VK_KHR_win32_keyed_mutex`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/dbfd1b68c449c1f339e3dfd5b90b458cf5424882
Vulkan API specifications 1.0.55 released
« Reply #27 on: July 17, 2017, 11:03:20 PM »
Change log for July 15, 2017 Vulkan 1.0.55 spec update:
  * Bump API patch number and header version number to 55 for this update.
Github Issues:
  * Removed unintended optional parameter in +vk.xml+ from the
    pname:pWaitSemaphores member of slink:VkPresentInfoKHR, which resulted
    in the generation of an incorrect implicit valid usage clause allowing
    pname:pWaitSemaphores to be NULL even when pname:waitSemaphoreCount is
    non-zero (public issue 491).
  * Add missing attribute to +vk.xml+ documenting that
    slink:VkSwapchainCounterCreateInfoEXT extends
    slink:VkSwapchainCreateInfo (public issue 510).
  * Add const qualifier for some `VK_EXT_debug_market` extension command
    parameters that were missing it (public issue 513).
  * Fix definition of q and level~base~ in
    <<textures-image-level-selection,Image Level(s) Selection>> (public
    issue 515).
  * Clarify lifetime requirement for slink:VkRenderPass objects used in
    object creation (public issue 516).
  * Fix link to floating/normalized fixed-point conversion from
    <<interfaces-fragmentoutput,Fragment Output Interface>> (public issue
    521).
Internal Issues:
  * Update the style guide to include the general structure of a Vulkan
    command name, the specific rule for using "`Get`" vs. "`Enumerate`" in
    names, and a table of verbs commonly used in command names (spinoff of
    internal issue 753).
  * Clarified the behavior of automatic layout transitions in case of
    attachment views that are 2D or 2D array views of 3D images. In
    addition, restructured the valid usage clauses corresponding to the
    members of the slink:VkImageSubresourceRange structure and added missing
    valid usage clauses for its pname:baseMipLevel and pname:baseArrayLayer
    members (internal issues 803, 849).
  * Modify `GL_KHR_vulkan_glsl` specification to allow explicit std430 on a
    push_constant declaration (internal issue 919).
Other Commits:
  * Modify <<synchronization-framebuffer-regions, Framebuffer Region
    Dependencies>> to use synchronization scope terminology.
  * Add ename:VK_COLOR_SPACE_EXTENDED_SRGB_NONLINEAR_EXT to the
    `VK_EXT_swapchain_colorspace` extension.
  * Replace XML comments with `comment` attributes and/or tags, to enable
    tools which transform the XML without loss of information.
  * Replace `validextensionstructs` with `structextends`, which is tagged in
    the child structure instead of the parent. This makes it slightly
    simpler to add new structs to the XML, causes fewer merge conflicts, and
    the information is kept localized to the extension structures where it
    belongs. The old `validextensionstructs` attributes will be retained
    until we're certain this doesn't cause problems with known consumers of
    +vk.xml+.
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/712755f6883af760b325bc795c23050cac3255b6
Vulkan API specifications 1.0.56 released
« Reply #28 on: July 22, 2017, 09:18:47 AM »
Change log for July 21, 2017 Vulkan 1.0.56 spec update:
  * Bump API patch number and header version number to 56 for this update.
Github Issues:
  * Add valid usage statements for commands introduced by
    `VK_EXT_debug_report` and `VK_EXT_debug_marker` extensions, regarding
    the valid pname:object and pname:objectType values (public issue 495).
  * Modify `GL_KHR_vulkan_glsl` specification to document that uniform and
    buffer block arrays each take only a single binding (public issue 514).
  * Add `KHX` author tag to +vk.xml+ (public issue 526).
Internal Issues:
  * Document use of code: macro for non-Vulkan APIs in the style guide
    (internal issue 863).
  * Document that reference page open block delimiters must not contain
    asciidoc section markup in the style guide (internal issue 898).
  * Fix <<spirvenv,SPIR-V appendix>> to say
    code:VariablePointersStorageBuffer instead of
    code:VariablePointersUniformBufferBlock (internal issue 928).
Other Commits:
  * Add missing extension structures to dependency attributes in +vk.xml+.
New Extenions:
  * `VK_EXT_depth_range_unrestricted`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/80af5ce5a24c6801a93efc8c0259436a1a61f45a
Vulkan API specifications 1.0.57 released
« Reply #29 on: August 01, 2017, 01:52:36 PM »
Change log for August 1, 2017 Vulkan 1.0.57 spec update:
  * Bump API patch number and header version number to 57 for this update.
Github Issues:
  * Fix error in description of ename:VK_FORMAT_ETC2_R8G8B8A8_SRGB_BLOCK
    block size (public issue 342).
  * Update documentation of ename:VK_PIPELINE_CREATE_ALLOW_DERIVATIVES_BIT
    to explicitly mention both graphics and compute pipelines (public issue
    525).
Internal Issues:
  * Document that
    slink:VkPhysicalDeviceLimits::pname:framebufferColorSampleCounts does
    not cover integer formats (internal issue 550).
  * Add a note under slink:VkImageViewCreateInfo describing how values meant
    for one format can be sanitized when used via another format (internal
    issue 927).
  * Add valid usage statements to ftext:vkCmd* documenting that image
    subresources used as attachments must not be accessed as non-attachments
    in a render pass (internal issue 929).
  * Remove obsolete 'validextensionstructs' attribute from +vk.xml+, the XML
    schema, and the schema documentation (internal issue 946).
New Extensions:
  * `VK_AMD_mixed_attachment_samples`
  * `VK_EXT_post_depth_coverage`
  * `VK_KHR_relaxed_block_layout`
  * `VK_NV_depth_range_unrestricted`
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/c8c0862dee6ba9ed861e87648c59fcdf8a032f3a
Vulkan API specifications 1.0.58 released
« Reply #30 on: August 14, 2017, 05:07:18 PM »
Change log for August 14, 2017 Vulkan 1.0.58 spec update:
  * Bump API patch number and header version number to 58 for this update.
Github Issues:
  * Update the <<interfaces-resources-descset,Descriptor Set Interface>>
    section to allow multiple variables with the same descriptor set/binding
    decorations, and require that all variables that are statically used
    must be consistent with the pipeline layout. Allow
    ename:VK_DESCRIPTOR_TYPE_COMBINED_IMAGE_SAMPLER to be used with texture
    and sampler variables (public issues 522, 524).
Internal Issues:
  * Replace networkx package used for extension dependency generation with a
    homegrown network dependency traverser (internal issue 713).
  * Specify in the <<interfaces-fragmentoutput, Fragment Output Interface>>
    section that if a fragment shader writes integers that cannot be
    represented in the format of the colour attachment, then the result is
    undefined (internal issue 893).
  * Separate malformed valid usage statement for
    slink:VkPipelineRasterizationStateCreateInfo into two (internal issue
    918).
  * Fix cases where the term 'pNext chain' is incorrectly used in reference
    to functions, rather than their parameters. Replace 'pNext list' with
    'pNext chain'. Fixed typo in the example code of
    +VK_KHR_dedicated_allocation+ (internal issue 944).
  * Fix typo in elink:VkExternalSemaphoreHandleTypeFlagBitsKHR enum
    descriptions, replacing
    etext:VK_EXTERNAL_SEMAPHORE_HANDLE_TYPE_FENCE_FD_BIT_KHR with
    ename:VK_EXTERNAL_SEMAPHORE_HANDLE_TYPE_SYNC_FD_BIT_KHR, and make the
    description more consistent with
    VK_EXTERNAL_FENCE_HANDLE_TYPE_SYNC_FD_BIT_KHR (internal issue 950).
Other Issues:
  * Clarify how pipeline stage masks affect
    <<synchronization-pipeline-stages-masks, access and synchronization
    scopes>>.
  * Clarify that dedicated allocations do not allow aliasing in the
    flink:vkBindBufferMemory and flink:vkBindImageMemory valid usage
    statements.
  * Correct specification of pname:dynamicCount for push_constant token in
    slink:VkIndirectCommandsLayoutNVX.
New Extensions:
  * `VK_EXT_shader_viewport_index_layer`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/cd4de492bf04b4a7542a5029ae4b998f117a7ac8
Vulkan API specifications 1.0.59 released
« Reply #31 on: August 20, 2017, 12:19:43 PM »
Change log for August 19, 2017 Vulkan 1.0.59 spec update:
  * Bump API patch number and header version number to 59 for this update.
Github Issues:
  * Fix a few missing Implicit Valid Usage statements to indicate that a
    common parent of two objects is required (public issue 497).
  * Clarify render pass synchronization language for
    slink:VkSubpassDependency and \<\<renderpass,render passes>> (public
    issue 531).
  * Rename ename:VK_STRUCTURE_TYPE_SURFACE_CAPABILITIES2_EXT to
    ename:VK_STRUCTURE_TYPE_SURFACE_CAPABILITIES_2_EXT for consistency, and
    add an alias for backwards compatibility (public issue 539).
Internal Issues:
  * Add an explanation to the \<\<interfaces-builtin-variables-layer,
    code:Layer>> description explaining that writing to invalid layers
    results may or may not result in primitives being processed and fragment
    shaders being run, and gives undefined results in the framebuffer
    (internal issue 614)
  * Add valid usage statement for slink:VkDescriptorSetLayoutBinding
    requiring that input attachment descriptor bindings must not use
    non-fragment stages (internal issue 933).
Other Issues:
  * Makes description of pname:loadOp and pname:storeOp easier to read in
    the \<\<renderpass-load-store-ops>> section.
New Extensions:
  * `VK_EXT_shader_stencil_export`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/bbb637d6dbe78a5d8c1c8f8f2129353b0e4dc1dc
Vulkan API specifications 1.0.60 released
« Reply #32 on: September 04, 2017, 04:33:24 PM »
Change log for September 5, 2017 Vulkan 1.0.60 spec update:
  * Bump API patch number and header version number to 60 for this update.
Github Issues:
  * Document that <<queries-timestamps, Timestamp Queries>> can only be
    meaningfully compared when they are written from the same queue (public
    issue 216).
  * Document that the `<extension>` tag `type` attribute is required for
    non-disabled extensions (derived from, but does not close public issue
    354).
  * Clean up registry schema length attribute descriptions to be consistent
    and correct (public issue 555).
Internal Issues:
  * Replace as much of the hand-written extension appendix metadata as
    possible with asciidoc includes generated from corresponding attributes
    of +vk.xml+, and enhance the style guide to match. This avoids
    inconsistencies between +vk.xml+ and the appendices, and produces a more
    uniform style (internal issue 137).
  * Remove the generated extDependency.{py,sh} files from the tree and
    create them dynamically on demand instead, reducing merge conflicts
  * Add a prototype tool for generating in-place difference markup for
    sections guarded by asciidoc conditionals, and new syntax for open
    blocks to support it (internal issue 833).
  * Remove unnecessary restriction of etext:*SYNC_FD_BIT_KHR external handle
    types to the same physical device in the
    slink:VkPhysicalDeviceIDPropertiesKHR,
    flink:VkImportMemoryWin32HandleInfoKHR,
    slink:VkImportFenceWin32HandleInfoKHR, slink:VkImportFenceFdInfoKHR,
    slink:VkImportSemaphoreWin32HandleInfoKHR,
    slink:VkImportSemaphoreFdInfoKHR
    <<external-memory-handle-types-compatibility, External memory handle
    types compatibility>>, <<external-semaphore-handle-types-compatibility,
    External semaphore handle types compatibility>>, and
    <<external-fence-handle-types-compatibility, External fence handle types
    compatibility>> sections (internal issue 956).
Other Issues:
  * Remove dependency of +VK_KHX_device_group+ on +VK_KHR_swapchain+ (there
    is an interaction, but not a strict dependency), and add a new
    `extension` attribute to the `<require` XML tag to allow classifying a
    subset of interfaces of an extension as requiring another extension.
    Update the registry schema and documentation accordingly.
New Extensions:
  * `VK_AMD_shader_fragment_mask` (and related `GL_AMD_shader_fragment_mask`
    GLSL extension)
  * `VK_EXT_sample_locations`
  * `VK_EXT_validation_cache`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/df88ded281466e08fcef9730ec5600f0f5535bce
Vulkan API specifications 1.0.61 released
« Reply #33 on: September 15, 2017, 04:14:58 PM »
Change log for September 15, 2017 Vulkan 1.0.61 spec update:
  * Bump API patch number and header version number to 61 for this update.
Github Issues:
  * Provide alternate length attributes (altlen=) in the XML schema, for
    those using length attributes to generate code instead of documentation
    (public issue 555).
  * Fix erroneous references to `latex:` being used for asciidoc math
    markup, rather than `latexmath:` (public pull request 556).
  * Add author ID to XML for Kazan software renderer (public pull request
    557).
Internal Issues:
  * Add the <<fundamentals-abi,Application Binary Interface>> section
    describing platform ABI requirements and recommendations, add examples
    of function and function pointer declarations to the
    <<boilerplate-platform-specific-calling-conventions, Platform-Specific
    Calling Conventions>> section, and remove related language that existed
    elsewhere in the specification (internal issue 64).
  * Describe where to document valid usage interactions of chained
    structures in the style guide, and fix one case now appearing in
    slink:VkBufferCreateInfo instead of the child
    slink:VkDedicatedAllocationBufferCreateInfoNV structure (internal issue
    715).
  * Add example to the style guide of describing enumerated types which are
    empty when the spec is built without relevant extensions enabled, and
    apply it to existing examples for
    elink:VkDescriptorSetLayoutCreateFlagBits and
    elink:VkSubpassDescriptionFlagBits (internal issue 864).
  * Add a note to the <<fundamentals-validusage-enums, Valid Usage for
    Enumerated Types>> section that the special values suffixed with
    etext:_BEGIN_RANGE, etext:_END_RANGE, etext:_RANGE_SIZE and
    etext:_MAX_ENUM are not part of the API and should: not be used by
    applications (internal issue 872).
  * Added note to flink:vkCmdUpdateBuffers explaining the performance
    penalty for copies done in this way, and why the upper copy limit is
    what it is (internal issue 952).
  * Update `VK_KHX_device_group` to split some functionality into the new
    `VK_KHR_bind_memory2` extension, and rename that functionality (internal
    issue 969).
  * Remove *Status* fields from extension appendices, since they are by
    definition published and complete by the time they reach the public
    github repository (internal issue 973).
Other Issues:
  * Update Data Format specification dependency to version 1.2 and change
    references to DF sections accordingly.
  * Update XML to make the pname:pAllocator parameter of
    flink:vkRegisterDeviceEventEXT and flink:vkRegisterDisplayEventEXT in
    the `VK_EXT_display_control` extension as optional.
New Extensions:
  * `VK_KHR_bind_memory2`
  * `VK_KHR_image_format_list`
  * `VK_KHR_maintenance2`
  * `VK_KHR_sampler_ycbcr_conversion`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/0cc6bba634aeecb88e4b43f1bdfd84a339c1869e
Vulkan API specifications 1.0.62 released
« Reply #34 on: October 07, 2017, 04:59:22 PM »
Change log for October 6, 2017 Vulkan 1.0.62 spec update:
  * Bump API patch number and header version number to 62 for this update.
Github Issues:
  * Move asciidoc conditionals for `VK_KHR_maintenance1` in
    slink:VkDescriptorSetAllocateInfo so valid usage statements for
    `VK_KHR_push_descriptor` aren't accidentally removed when the first
    extension isn't enabled (public issue 573).
  * Fixed errors in API example code for
    flink:vkUpdateDescriptorSetWithTemplateKHR and
    flink:vkCmdPushDescriptorSetWithTemplateKHR (public issue 577).
Internal Issues:
  * Specify constraints on concurrent access to fences that share payload in
    the <<synchronization-fences-importing, Importing Fence Payloads>> and
    <<synchronization-semaphores-waiting-state, Semaphore State Requirements
    For Wait Operations>> sections (internal issue 820).
  * Define the term "`retired swapchain`", reorganize some swapchain
    language, and improve language for pname:oldSwapchain in
    flink:VkSwapchainCreateInfoKHR, the <<swapchain-wsi-image-create-info>>
    table, flink:vkDestroySwapchainKHR, and flink:vkAcquireNextImage2KHX
    (internal issue 869).
  * Describe in the <<writing-arrays, Describing Properties of Array
    Elements>> section of the style guide how and when to use "`each`" and
    "`any`" to refer to properties of array elements, and make those uses in
    the specification consistent (internal issue 884).
  * Clarified that events cannot be used for cross-queue synchronization in
    the <<synchronization-events, Events>> section and for
    flink:vkCmdWaitEvents (internal issue 970).
  * Add success and error codes to +vk.xml+ for
    flink:vkCreateValidationCacheEXT (internal issue 995).
  * Clarify aspect mask usage for image memory barriers of multi-plane
    images in slink:VkImageSubresourceRange, slink:VkImageMemoryBarrier, and
    the <<textures-layout-validation, Layout Validation>> section (internal
    issue 996).
Other Issues:
  * Fixed typo in flink:VkRenderPassSampleLocationsBeginInfoEXT (renamed
    field pname:pSubpassSampleLocations to
    pname:pPostSubpassSampleLocations).
  * Add missing buffer usage requirements for indirect draws in
    flink:vkCmdDrawIndirect, flink:vkCmdDrawIndirectCountAMD,
    flink:vkCmdDrawIndexedIndirect, and
    flink:vlCmdDrawIndexedIndirectCountAMD.
  * Modify Makefile to allow specification to build in git "`detached HEAD`"
    state.
  * Update valid usage ID generation script to allow recursively operating
    on all `.txt` files in a specified directory, and move the `startVUID`
    tracking information into a separate python file that is automatically
    updated by the script.
New Extensions:
  * Add +vk.xml+ entries for pending `VK_ANDROID_native_buffer` extension
    (note, this extension is not yet enabled).
  * `VK_AMD_shader_image_load_store_lod`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/6012d138c7d6939e00772f80477569b25abad52b
Vulkan API specifications 1.0.63 released
« Reply #35 on: October 15, 2017, 07:07:36 AM »
Change log for October 13, 2017 Vulkan 1.0.63 spec update:
  * Bump API patch number and header version number to 63 for this update.
Github Issues:
  * Add missing valid usage statements for ptext:maxDescriptorSets*,
    ptext:maxPerStageDescriptorInputAttachments, and
    ptext:maxPerStageResources to slink:VkPipelineLayoutCreateInfo.txt,
    flink:VkComputePipelineCreateInfo, and
    flink:VkGraphicsPipelineCreateInfo (public issue 546).
  * Fix typos in ftext:vkCmdDraw*AMD descriptions (public pull request 549).
  * Fixed flink:vkCmdWriteTimestamp so it is not unnecessarily restricted to
    queues supporting graphics or compute operations (public issue 558).
  * Improvements to valid usage generator for output `*Flags` pointer
    parameters and for some `void *` parameters (public pull requests 560,
    562).
  * Document `altlen` attribute in XML schema as valid C99 syntax and tweak
    `vk.xml` to match (public pull request 566).
  * Clarify when pname:fence is signaled by flink:vkQueueSubmit in a more
    obvious place (public issue 577).
Internal Issues:
  * Specify a whitelist of supported SPIR-V Storage Classes in the
    appendix (internal SPIR-V issue 166).
  * Relax the shared semaphore wait timeout requirement in the
    <<synchronization-semaphores-importing, Importing Semaphore Payloads>>
    section (internal issue 820).
  * Update the <<textures-image-level-selection, Image Level(s) Selection>>
    equations so that the parameters returned by the level-of-detail query
    appear explicitly, also fixing the issue that linear filtering would
    select a level below the base level for magnification (internal issue
    926).
  * Disallow creation of a swapchain with zero pname:imageExtent in
    slink:VkSurfaceCapabilitiesKHR and slink:VkSwapchainCreateInfoKHR
    (internal issue 1020).
Other Issues:
  * Clarify in <<textures-operation-validation,Image View Validation>> that
    the layout of subresources in an image view must have a layout that
    matches that written into the descriptor, and that this section is about
    validating image views, not images.
New Extensions:
  * `VK_EXT_global_priority`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/52d809dd04be4b063adb715eb5a2114e30a9f6d4
Vulkan API specifications 1.0.64 released
« Reply #36 on: October 21, 2017, 10:03:46 AM »
Change log for October 20, 2017 Vulkan 1.0.64 spec update:
  * Bump API patch number and header version number to 64 for this update.
Github Issues:
  * Add chapter name to the PDF page footer (public pull request 458).
  * Fix several mistaken references to the nonexistent etext:VK_DEVICE_LOST
    status to etext:VK_ERROR_DEVICE_LOST (public pull request 502).
  * Fix description of the tlink:PFN_vkDebugReportCallbackEXT debug report
    callback function pointer to match the validation layer behavior (public
    issue 534).
  * Document experimental KHX extensions and alternate vendor author IDs
    also ending in X in more detail in the <<extensions, Layers &
    Extensions>> appendix, the extensions section of the style guide, and
    the registry schema description document (public issues 536, 580).
  * Fix references to ptext:pDepthStencil to properly refer to
    pname:pDepthStencilState or pname:pRasterizationState as appropriate in
    the slink:VkGraphicsPipelineCreateInfo description (public issue 542).
  * Fix wrong parameter name in slink:VkPipelineMultisampleStateCreateInfo
    valid usage (public pull request 571).
Internal Issues:
  * Update the style guide to describe how to write LaTeX math expressions
    in table cells (internal issue 908).
  * Define how framebuffer-local dependencies work between subpasses with
    the same or different numbers of samples, in the
    slink:VkSubpassDescription and <<synchronization-framebuffer-regions,
    Framebuffer Region Dependencies>> sections. This clarifies which samples
    in an input attachment you are allowed to access after a
    framebuffer-local dependency (internal issue 915).
  * Specify which storage classes can have an initializer in the
    <<spirvenv-module-validation, Validation Rules within a Module>> section
    (internal issue 1023).
  * Use "LOD" consistently for "level-of-detail", to eliminate spelling
    inconsistencies. The term is already standardized in the Glossary
    (internal issue 1027).
Other Issues:
  * Fix false positives in Makefile dependencies when rules fail, by
    deleting partially-made targets.
New Extensions:
  * `VK_AMD_shader_info`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/5436521608c40f324b397693f5bb758d666e3f55
Vulkan API specifications 1.0.65 released
« Reply #37 on: October 28, 2017, 02:00:57 PM »
Change log for October 27, 2017 Vulkan 1.0.65 spec update:
  * Bump API patch number and header version number to 65 for this update.
Github Issues:
  * Replaced inaccurate "`pixel`" with "`texel`" or "`compressed texel
    block`" as appropriate in the <<sparsememory, Sparse Resources>> chapter
    (public issue 86).
  * Attempt to clarify security/integrity guarantees in the
    <<fundamentals-errors, Errors>> section (public issue 147).
  * Update the <<memory-device,Device Memory>> section with clarifications
    and markup fixes (public pull request 194).
  * Fix typo VkDeviceCreateInfo -> slink:VkDebugMarkerObjectNameInfoEXT in
    sample code for `VK_EXT_debug_marker` extension (public pull request
    227).
  * Clarified slink:VkFramebufferCreateInfo language regarding concurrent
    use of attachment resources during a render pass instance (public issue
    299).
  * Added overlap rules for destination regions in <<copies,copy commands>>.
    Also unified the sparse and non-sparse source-destination overlap rules,
    since the non-sparse rules were technically inaccurate in the face of
    aliasing in flink:vkBindMemory2 - the new rules are true regardless
    (public issue 317).
  * Clarified the <<features-features-samplerAnisotropy,
    pname:samplerAnisotropy feature>> to only affect the
    slink:VkSamplerCreateInfo::pname:anisotropyEnable value, and that
    pname:maxAnisotropy is ignored when pname:anisotropyEnable is VK_FALSE
    (public issue 503).
  * Clarify pointer valid usage statements to use "`valid pointer to valid
    _object_`" terminology and update the
    <<fundamentals-validusage-pointers,Valid Usage for Pointers>> section
    accordingly (public pull request 547).
  * Some operations that use integer coordinates can also accept a LOD to
    sample from. Add a description of that selection and the validity
    conditions in the new <<textures-integer-coordinate-operations, Integer
    Texel Coordinate Operations>> section (public issue 548).
  * Update stext:VkImageSubresource* valid usage statements (public pull
    request 550).
  * Added text tying ename:VK_OUT_OF_POOL_MEMORY error for
    flink:vkAllocateDescriptorSets to the number of descriptor types in the
    allocating pool. Removed redundant "`length`" text about number of
    descriptors returned (public issue 582).
  * Update slink:VkSwapchainCreateInfoKHR descriptions (public pull request
    585).
  * Update slink:VkPipelineViewportWScalingStateCreateInfoNV and related
    structures' valid usage statements (public pull request 587).
  * Change some dates to conform to ISO 8601 as specified in the style guide
    (public pull request 601).
  * Fix some math markup problems and be more consistent in use of asciidoc
    math markup (public pull request 602).
Internal Issues:
  * Clarified that attribute reads from incomplete vertex buffer elements
    are considered out of bounds accesses, in the
    slink:VkPhysicalDeviceFeatures and flink:vkCmdBindVertexBuffers.txt
    sections (internal issue 842).
Other Issues:
New Extensions:
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/0a1c49409f23100118f03bb5b33ab53f009c13f8
Vulkan API specifications 1.0.66 released
« Reply #38 on: November 27, 2017, 05:57:20 PM »
Change log for November 27, 2017 Vulkan 1.0.66 spec update:
  * Bump API patch number and header version number to 66 for this update.
Github Issues:
  * Clarified how and when ename:VK_ERROR_TOO_MANY_OBJECTS is generated in
    flink:vkAllocate Memory, and remove incorrect valid usage statement
    about exceeding the API limit (public issue 356).
  * Minor clarification of the description of
    flink:vkUpdateDescriptorSetWithTemplateKHR::pname:descriptorUpdateTemplate
    (public issue 564).
  * Minor fixes for flink:vkCmdSetViewportWScalingNV (public pull request
    588).
  * Fix random name markup issues (public pull request 603).
  * Fix code:BuiltIn decoration typo in the <<fxvertex-attrib, Vertex
    Attributes>> section (public pull request 606).
  * Fix synchronization language following the definition of
    flink:vkAcquireNextImageKHR (public issue 607).
  * Restore descriptions of several commands and structures missing from the
    generated spec due to a mistyped asciidoctor conditional (public issue
    612).
  * Fix 1.0.41 changelog to refer to public issues 403/404 (public issue
    618).
Internal Issues:
  * Refactor valid usage statements with internal conditionals in
    `copies.txt`, `pipelines.txt`, `renderpass.txt`, and `resources.txt` so
    each branch of the conditional appears as a standalone statement which
    can contain a separate VUID. This should have no impact on the generated
    specs, but is necessary given the present state of the VU extractor and
    the validation layer code that consumes them (internal issue 1043).
  * Fix VkQueueGlobalPriorityEXT enum values missing _EXT suffix (internal
    issue 1045).
  * Clarified initial ownership of resources bound to shared memory objects,
    (internal issue 1068).
  * Fix duplicated valid usage ID tag for flink:vkCmdCopyImage, and make the
    required layouts include ename:VK_IMAGE_LAYOUT_TRANSFER_SRC_OPTIONAL in
    both cases (internal issue 1084).
Other Issues:
  * Remove the noise functions from GLSL for SPIR-V for Vulkan in the
    `GL_KHR_vulkan_glsl.txt` extension.
New Extensions:
  * `VK_EXT_external_memory_host`
  * `VK_EXT_external_memory_dma_buf`
  * `VK_EXT_queue_family_foreign`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/64fa8ef4df3bff37214e717abe490f7ea7ea44b0
Vulkan API specifications 1.0.67 released
« Reply #39 on: January 06, 2018, 07:30:18 PM »
Change log for January 5, 2018 Vulkan 1.0.67 spec update:
  * Bump API patch number and header version number to 67 for this update.
  * Update copyright dates to 2018
Github Issues:
  * Fix texture lookup functions in `GL_KHR_vulkan_glsl` specification
    (public pull request 363).
  * Clarify the state waited semaphores are left in when a call to
    flink:vkQueuePresentKHR fails (public issue 572).
  * Cleanup descriptions of slink:VkObjectTablePushConstantEntryNVX and
    slink:VkObjectTableDescriptorSetEntryNVX (public issue 583)
  * Remove redundant flink:vkCmdSetDiscardRectangleEXT valid usage
    statements (public pull 586).
  * Make dynamic state array length valid usage statements implicit for
    flink:vkCmdSetViewportWScalingNV, flink:vkCmdSetDiscardRectangleEXT, and
    flink:vkCmdSetViewport (public pull 589).
  * Clarify meaning of window extent (0,0) in slink:VkSwapchainKHR for the
    Windows and X11 platforms, in their respective extensions (public issue
    590).
  * Allow flink:vkGetPastPresentationTimingGOOGLE to return
    ename:VK_INCOMPLETE (public issue 604).
  * Add synchronization valid usage statements to flink:vkAcquireNextImage
    (public pull 611).
  * Fix some broken external links and internal xrefs (public pull 613).
  * Clean up slink:VkViewport valid usage statements in the presence or
    absence of relevant extensions (public pull 623).
  * Remove
    ename:VK_IMAGE_LAYOUT_DEPTH_READ_ONLY_STENCIL_ATTACHMENT_OPTIMAL_KHR
    token from VK_KHR_maintenance2 from the non-extension VU path for
    slink:VkGraphicsPipelineCreateInfo (public issue 628).
  * Miscellaneous minor markup fixes - extension name strings (public pull
    631), Notes (pull 633), queue names emitted by generator scripts (pull
    634), block formatting in slink:VkDescriptorUpdateTemplateEntryKHR (pull
    635), ename:VK_FORMAT_FEATURE_SAMPLED_IMAGE_FILTER_CUBIC_BIT_IMG (pull
    641), quotes and apostrophes (pull 643),
  * Miscellaneous minor grammar fixes (public pull 644).
  * Fix markup macros so usage like ptext:*Src* works (public pull 647).
Internal Issues:
  * Clarify in the `VK_KHR_surface` and `VK_KHR_swapchain` extensions that
    parameter combinations which aren't supported for normal images are also
    unsupported for presentable images, even if the parameter values are
    individually supported as reported by the surface capability queries
    (internal issue 1029).
  * Fixed XML typo in the valid value field of the pname:sType member of
    slink:VkPhysicalDeviceExternalMemoryHostPropertiesEXT (internal issue
    1100).
Other Issues:
  * Add memory semantics validity rules to the <<spirvenv-module-validation,
    Validation Rules within a Module>> section of the SPIR-V environment
    appendix, and specify that sequentiality consistency is not supported.
    This forbids certain cases like "`Load+Release`" that we don't expect to
    ever be meaningful.
  * Document mapping of OpenGL Shading Language barriers to SPIR-V scope and
    semantics in the `GL_KHR_vulkan_glsl` specification.
New Extensions:
  * `VK_EXT_conservative_rasterization`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/b7b1c3a65d370013cbd9e1985d59628a88f818a8
