Author Topic: Vulkan API specifications 1.0.4 released  (Read 65870 times)
« on: February 26, 2016, 01:51:30 PM »
The Khronos Group has just updated the specifications of the Vulkan API.
Here are the changes:
* Bump API patch number from 3 to 4 for the first public update to the
    spec. Add patch number to the spec title (this will be done
    automatically from XML, later).
  * Fixes for numerous editorial issues. Regularize descriptions of
    variable-length array queries. Properly tag enumerants so they come
    out in the right font (many were mislabeled in usage tags in vk.xml,
    or not tagged). Spelling and markup corrections (public issue 4).
  * Fix typos and clearly separate description of different types of
    memory areas (public issue 5).
  * Use standards-compliant preprocessor guard symbols on headers
    (public issue 7).
  * Note that Github users can't currently set labels on issues, and
    recommend a fallback approach (public issue 15).
  * Use latexmath prefix on len= attributes (public issue 29).
  * Make flink:vkCmdUpdateBuffer pname:dataSize limit consistent (public
    issue 65).
  * Add VK_KHR_mirror_clamp_to_edge extension to core API branch, as an
    optional feature not introducing new commands or enums (internal
    issue 104).
  * Cleanup invariance language inherited from the GL specification to
    not refer to nonexistent (GL-specific) state (internal issue 111).
  * Modify the flink:vkCmdDrawIndexed pname:vertexOffset definition to
    not be the "base offset within the index buffer" but rather the
    "value added to the vertex index before indexing into the vertex
    buffer" (internal issue 118).
  * Fix drawing chapter in the "Programmable Primitive Shading" section
    where it described categories of drawing commands. It referenced
    flink:vkCmdDrawIndexed twice. Replace the second reference with
    flink:vkCmdDrawIndexedIndirect (internal issue 119).
  * Typo fixed in <<sparsememory-examples-advanced,Advanced Sparse
    Resources>> sparse memory example (internal issue 122).
  * Add flink:VkDisplayPlaneAlphaFlagsKHR to <require> section of
    VK_KHR_display extension (internal issue 125)
  * Add missing optional="false,true" to
    flink:vkGetImageSparseMemoryRequirements
    pname:pSparseMemoryRequirementCount parameter (internal issue 132)
  * Rename ename:VK_STRUCTURE_TYPE_DEBUG_REPORT_CREATE_INFO_EXT to
    ename:VK_STRUCTURE_TYPE_DEBUG_REPORT_CALLBACK_CREATE_INFO_EXT
    (internal issue 133)
  * Fix a handful of broken cross-references in the
    <<samplers,Samplers>> chapter (internal issue 134).
  * Fix "Input Attachement" GLSL example to use correct syntax (internal
    issue 135).
  * Update XML schema and documentation to accomodate recently added
    attributes for validity. Add some introductory material describing
    design choices and pointing to the public repository to file issues.
  * Put include of validity in the core spec extensions chapter on its
    own line, so that asciidoc is happy.
  * Fix vertexOffset language to specify that it's the value added to
    the vertex index before indexing into the vertex buffer, not the
    base offset within the index buffer.
  * Fix error in the description of flink:vkCmdNextSubpass.
Link: https://www.khronos.org/registry/vulkan/
Vulkan resource list: http://www.geeks3d.com/20160205/vulkan-programming-resources-list/
Vulkan API specifications 1.0.6 released
« Reply #1 on: March 13, 2016, 03:32:17 PM »
* Bump API patch number and header version number to 6 for this
    update.
Github Issues:
  * Define 'invocation group' for compute and graphics shaders. Cleanup
    definition and use of 'workgroup', and add glossary entries (public
    issue 1).
  * Various minor editorial fixes (public issue 33).
  * Clarify locations for block members in the
    &lt;&lt;interfaces-iointerfaces-locations,Location Assignment>>
    section (public issue 45).
  * Editorial fixes for &lt;&lt;commandbuffer-allocation,Command Buffer
    Allocation>> section (public issues 54, 59).
  * Clarify behavior of depth test in the &lt;&lt;fragops-depth,Depth
    Test&gt;&gt; section (public issues 80, 81).
  * Remove discussion of return codes from
    flink:vkGetPhysicalDeviceSparseImageFormatProperties and
    flink:vkGetImageSparseMemoryRequirements, which don't return values
    (public issue 82).
  * Allow flink:vkCmdDrawIndirect and flink:vkCmdDrawIndexedIndirect
    pname:drawCount of 0, as well as 1, when the multiDrawIndirect
    feature is not supported (public issue 88).
  * Remove confusing wording in the &lt;&lt;features-limits,Limits>>
    section describing the slink:VkPhysicalDeviceLimits
    pname:minTexelBufferOffsetAlignment,
    pname:minUniformBufferOffsetAlignment, and
    pname:minStorageBufferOffsetAlignment members as both minimums and
    maximums (public issue 91).
  * Clarified that only the RGB components should be affected in places
    where sRGB is referred to in the spec, such as ASTC formats. Minor
    re-wording to avoid "color space" when actively incorrect, now that
    we refer to the Data Format Spec which actually makes a distinction
    between color space and transfer function (public issue 94).
  * Treat pname:pPropertyCount == 0 consistently in
    flink:vkEnumerateInstanceLayerProperties and
    flink:vkEnumerateDeviceLayerProperties (public issue 99)
  * Cleanup minor editorial issues in chapters 14-17 (public issue 100).
  * Clarify definition of flink:vkEnumerateInstanceExtensionProperties
    and flink:vkEnumerateDeviceExtensionProperties (public issue 101).
  * Define the flink:vkEnumerateInstanceExtensionProperties and
    flink:vkEnumerateDeviceExtensionProperties pname:pLayerName
    parameter to be a pointer to a null-terminated UTF-8 string (public
    issue 101).
  * Rearrange "Missing information" references in mandatory format
    tables (public issue 101).
  * Clarify that the enumerated extensions returned by
    flink:vkEnumerateDeviceExtensionProperties will only include
    extensions provided by the platform or extensions implemented in
    implicitly enabled layers (public issue 101).
  * Miscellaneous editorial fixes. Include the Vulkan spec patch number
    in the PDF title. Fix label on &lt;&lt;fig-non-strict-lines,Non
    strict lines>> diagram. Use more easily distinguished symbols in
    tables in the &lt;&lt;features-required-format-support,Required
    Format Support>> section. Don't require FQDNs used as layer names be
    encoded in lower case if not possible, in the
    &lt;&lt;extensions-naming-conventions, Extension and Layer Naming
    Conventions>> section (public issues 101, 119, 121).
Internal Issues:
  * Fixed excessive spacing in tables in XHTML (internal issue 18).
  * Clarify that ename:VK_COMMAND_BUFFER_USAGE_ONE_TIME_SUBMIT_BIT
    applies to secondary command buffers. Previously spec only referred
    to the members of pname:pCommandBuffers being affected by this bit.
    Added a separate slink:VkSubmitInfo Valid Usage restriction
    specifying that ename:VK_COMMAND_BUFFER_USAGE_ONE_TIME_SUBMIT_BIT
    also applies to any secondary command buffers that are recorded into
    the primary command buffers in pname:pCommandBuffers (internal issue
    106).
  * Clarify that slink:VkDeviceCreateInfo::pname:pEnabledFeatures can be
    NULL (internal issue 117).
  * Remove "the value of" where it is redundant (e.g. speaking of an API
    parameter, struct member, or SPIR-V variable, but not when speaking
    of color components) (internal issue 175).
  * Forced patch version to always be 0 in the header. Add a
    "VK_API_VERSION_<major>_<minor>" macro for people to use to do the
    right thing. Add a VK_HEADER_VERSION which captures the header
    release number independent of the spec patch number (internal issue
    176).
  * Correct description of
    slink:VkPipelineShaderStageCreateInfo::pname:pName to "a pointer to
    a null-terminated UTF-8 string" (internal issue #197).
Other Commits:
  * Updated DataFormat spec reference to the new date for revision 5 of
    that spec.
  * Fixed KEEP option (to retain LaTeX intermediate files) in the
    Makefile to be included when edited there, as well as set on the
    command line.
  * Reserve and add "VK_IMG_filter_cubic" to the registry, and implement
    script functionality to add and remove validity from existing
    functions. Includes schema and readme changes.
  * Update GL_KHR_vulkan_glsl so push_constants do not have descriptor
    sets.
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/1f875738fd9bd0aca5d36bf36794b4b2903e74a9
Vulkan API specifications 1.0.7 released
« Reply #2 on: March 27, 2016, 08:15:03 AM »
Change log for March 25, 2016 Vulkan 1.0.7 spec update:
  * Bump API patch number and header version number to 7 for this
    update.
Github Issues:
  * Fix slink:VkSpecializationMapEntry example to avoid C/C++ strict
    aliasing issues (public issue 14).
  * Clarify the meaning of "matching" in flink:vkCmdBindDescriptorSets
    validity language (public issue 33).
  * Add stub reference pages so xrefs to not-yet-written pages don't
    generate 404 errors. However, the actual content of these pages
    still needs to be filled in as time allows (public issue 44, but
    does not close that issue out).
  * Remove incorrect validity statement for
    flink:vkGetImageSparseMemoryRequirements (public issue 85).
  * Reword the
    <<features-limits-bufferImageGranularity,bufferImageGranularity>>
    feature in terms of "aliasing", and clarify that it applies to
    bindings in the same memory object (public issue 90).
  * Clarify the relationship of the slink:VkPhysicalDeviceLimits
    pname:maxViewportDimensions and pname:viewportBoundsRange limits
    (public issue 92).
  * Specify sparse unbound texture replacement in the
    <<textures-texel-replacement,Texel Replacement>> section
    independently of robust buffer access language (public issue 100).
  * Add the <<fundamentals-architecture-model,Architecture Model>>
    section to explain architecture constraints Vulkan has chosen to
    accept in order to enable portable and performant code (public issue
    122).
  * State that an object must not be destroyed until *all* (not *any*)
    uses of that object have completed (public issue 123).
  * Minor editorial cleanup (public issues 129, 134, 146, 148).
  * Add validity language for layer and extension names to
    slink:VkDeviceCreateInfo matching that used for
    slink:VkInstanceCreateInfo (public issue 130).
  * Clean up terminology for the case when the bits set in one bitmask
    are a subset of the bits set in another bitmask (public issue 138).
  * Document that input attachments are UniformConstant not Input, in
    the <<interfaces-inputattachment,Fragment Input Attachment
    Interface>> section (public glslang bug 169).
Internal Issues:
  * Add max enum values to "flag bits" enums (internal issue #136).
  * Clarify language around the various uses of the term "block" in the
    <<appendix-compressedtex-bc,Block Compressed Image Formats>> section
    (internal issue #202).
  * Removed "expand" dependency from <enums> groups in vk.xml and added
    auto-generation code in the scripts to infer it instead, to ensure
    consistency. This caused renaming of sname:VkColorSpaceKHR and
    sname:VkPresentModeKHR etext:BEGIN_RANGE (etc.) tokens, but those
    tokens are metadata, not part of the API, and the Vulkan WG is OK
    with this change. This change adds ranges to two additional enums
    that were missing them due to not defining the "expand" attribute
    (internal issue 217).
  * Tweak makefile to generate ref page nroff (.3) files in the right
    output directory, working around an a2x limitation (internal issue
    223).
Other Commits:
  * Add validity requirements for flink:vkCmdCopyQueryPoolResults
    pname:dstBuffer parameter.
  * Fix ref page build to generate .3 targets in the right output
    directory.
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/8c3c9b4c85f2539b67148c2de9e2573154c92786
Vulkan API specifications 1.0.8 released
« Reply #3 on: April 03, 2016, 11:30:48 AM »
Change log for April 1, 2016 Vulkan 1.0.8 spec update:
  * Bump API patch number and header version number to 8 for this
    update.
Github Issues:
  * Specify in the validity language for flink:vkBeginCommandBuffer that
    pname:commandBuffer mustnot: currently be pending execution (public
    issue 96).
  * Describe depth comparison using the correct temporary variable names
    in the <<textures-depth-compare-operation,Depth Compare Operation>>
    section (public issue 100).
  * Clarify the order of descriptor update operations in the
    flink:vkUpdateDescriptorSets command (public issue 115).
  * Specify in the VK_KHR_swapchain extension that
    flink:vkAcquireNextImageKHR's pname:semaphore and pname:fence
    parameters cannot both be sname:VK_NULL_HANDLE (partly addresses,
    but does not fully close, public issue 117 / internal issue 246).
  * Change reference to the "lifetime" of a Vulkan command to
    "duration", and define the "duration" term (public issue 135).
  * Added valid usage language for slink:VkImageLayout to require both
    pname:height and pname:depth to be 1 for 1D images and pname:depth
    to be 1 for 2D images (public issue 137).
  * Fix SPIR-V example code in the
    <<descriptorsets-inputattachment,Input Attachment>> section to
    properly decorate the code:InputAttachmentIndex (public issue 139).
  * Fix reference to nonexistent pname:imageInfo in the description of
    flink:VkWriteDescriptorSet to refer to pname:pImageInfo (public
    issue 140).
Internal Issues:
  * Link to the fixed-function vertex chapter from the drawing chapter
    (internal issue #110)
  * Fix typo in slink:VkImageCreateInfo validity language:
    ptext:maxExtent.sampleCounts -> pname:sampleCounts (internal issue
    249).
  * Explain why the non-core token etext:VK_IMAGE_LAYOUT_PRESENT_SRC_KHR
    is used in the example in the
    <<synchronization-semaphores,Semaphores>> section (internal issue
    251).
  * Attempt to clarify in the VK_KHR_android_surface extension's
    <<platformQuerySupport_android,Android Platform Support>> section
    that there is no Android-specific WSI query, and why (internal issue
    252).
Other Commits:
  * Add missing language about ename:VK_INCOMPLETE being returned from
    array queries when the passed array is too short, in the
    VK_KHR_display, VK_KHR_swapchain, and VK_KHR_surface extensions.
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/ce3204c7dd53a0116ce3a91fd12919d606c306f5
Vulkan API specifications 1.0.9 released
« Reply #4 on: April 08, 2016, 03:58:26 PM »
Change log for April 8, 2016 Vulkan 1.0.9 spec update:
  * Bump API patch number and header version number to 9 for this
    update.
Github Issues:
  * Fix memory type preorder definition and clarify example list and source
    code for slink:VkMemoryRequirements and slink:VkMemoryHeap (public issue
    26).
  * Ensure slink:VkAllocationCallbacks are properly defined (public issue
    73).
  * Clarify the WSI extension language by switching from the fuzzier
    "ownership" language to more-consistent "acquire" language (public issue
    117).
  * Add language allowing allocation and freeing of memory scoped to the
    duration of any API command in the <<memory-allocation,Memory
    Allocation>> section (public issue 136).
  * Clarify the explicit location assignment always overrides the inherited
    location in the <<interfaces-iointerfaces-locations,Location
    Assignment>> section, even for the first member of a block (public issue
    141).
  * Fixed references to
    slink:VkCommandBufferInheritanceInfo::pname:pipelineStatistics (public
    issue 158).
  * Fix name of slink:VkBufferCopy::pname:size field in validity language
    for flink:vkCmdCopyBuffer (public issue 162).
Internal Issues:
  * Update GL_KHR_vulkan_glsl specification to clarify disallowance of
    spec-const arrays in initializers (internal issue 248).
  * Clarify <<interfaces-iointerfaces-matching,Interface Matching>> section
    to state that user-defined variable interface must match too (internal
    issue 250).
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/5d10fc3089ba0ec6a4c7d757a4b18a9ef215d2fb
Vulkan API specifications 1.0.10 released
« Reply #5 on: April 16, 2016, 04:59:27 PM »
Change log for April 15, 2016 Vulkan 1.0.10 spec update:
  * Bump API patch number and header version number to 10 for this
    update.
Github Issues:
  * Slightly tweak the <<memory-allocation,Host Memory>> allocator language
    so that an application wrapping the standard C alloc/free/realloc
    functions is still correct - the previous language was too strong with
    regards to freeing memory. Also made certain scenarios clearer - an
    implementation may now continue without error if an allocation failed
    and it is able to continue correctly (public issue 21).
  * Require that etext:VK_*_CREATE_SPARSE_BINDING_BIT is set when the
    corresponding etext:VK_*_CREATE_SPARSE_RESIDENCY_BIT is used, in the
    <<sparsememory-miptail,Mip Tail Regions>> section and related commands
    flink:vkCreateBuffer and flink:vkCreateImage (public issue 84).
  * Update the <<features,Features, Limits, and Formats>> chapter to clarify
    interactions between optional features and dynamic state for the
    pname:depthBiasClamp and pname:wideLines features (public issue 89).
  * Describe the code:WorkgroupSize builtin in the
    <<interfaces-builtin-variables,Built-In Variables>> section, and update
    the <<compute-shaders,Compute Shaders>> section to further clarify how
    to set the number of workgroups to execute in a compute shader (public
    issue 145).
  * Use the term *image subresource* everywhere instead of *subresource*,
    except for the special case of *host-accessible subresource*, which may
    be either an image subresource or buffer range (public issue 120)
  * Add a note to the <<features,Features, Limits, and Formats>> section
    about extensibility of structures (Public issue 165).
  * Fix return code flink:vkAcquireNextImageKHR when the timeout parameter
    is 0 to ename:VK_NOT_READY instead of ename:VK_TIMEOUT (public issue
    170).
  * Fix typo in slink:VkLayerProperties::pname:apiVersion field (public
    issue 172).
Internal Issues:
  * Fix a few minor internally-detected typos.
  * Minor formatting tweaks to pseudocode in the <<resources,Resource
    Creation>> chapter (internal issue 179).
  * Fix typo in the definition of point sampling for
    elink:VkCullModeFlagBits (internal issue 268).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/3b32b240f6a71aba8e8b746aaab8bba45883de77
Vulkan API specifications 1.0.12 released
« Reply #6 on: May 03, 2016, 01:34:37 PM »
* Bump API patch number and header version number to 12 for this
    update.
Github Issues:
  * Change valid usage statements intended to be "sub-points" to
    be actual sub-points (public issue 66).
  * Replace double negation in description of
    slink:VkRenderPassBeginInfo::pname:pClearValues (based on public
    merge 142).
  * Cleanup minor typos in spec, ref pages and XML, including those
    proposed in public pull requests 144, 150, 151, 167, 168, 181, and
    186.
  * Use *strict subset* in describing the partial order of memory
    property types for slink:VkMemoryType, and update the style guide
    accordingly (public issue 190).
  * Fix various "a image" -> "an image" typos (public issue 191).
  * Note in the <<fundamentals-validusage,Valid Usage>> and
    <<extensions-interactions,Extension Interactions>> sections that
    structures defined by extensions which may be passed in structure
    chains using the ptext:pNext member must: include initial
    ptext:sType and ptext:pNext members (public issue 192).
Internal Issues:
  * Remove duplicate language from the description of the pname:fence
    parameter to flink:vkQueueSubmit and improve validity language
    (internal issue 91).
  * Added documentation for "optional" attribute to XML readme.tex/pdf
    (internal issue 149).
  * Clarify the host-side data validity rules and behavior of
    flink:vkFlushMappedMemoryRanges and
    flink:vkInvalidateMappedMemoryRanges (internal issue 266).
Other Commits:
  * Added clarification to flink:vkCmdFillBuffer regarding the use of
    ename:VK_WHOLE_SIZE.
  * Fixed and documented implementation of "validextensionstructs"
    attribute. in XML processing scripts and readme.tex/pdf.
  * Add missing validity statements to flink:vkResetEvent and
    flink:vkCmdResetEvent.
  * Fix validity for the
    ename:VK_FORMAT_FEATURE_SAMPLED_IMAGE_FILTER_LINEAR_BIT flag.
    Correct all the draw/dispatch commands to mention optimally tiled
    images as well as linear tiled images, and say image VIEWS instead
    of images. Add validity statement to flink:vkCmdBlitImage
  * Replace the {apiname} macro with hardcoded "Vulkan", now that we've
    committed to that name.
  * Add the VK_AMD_rasterization_order extension to vk.xml.
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/75bbb5f4d52321eed41337cc463aa036748a1352
Vulkan API specifications 1.0.25 released
« Reply #7 on: August 29, 2016, 08:34:36 AM »
* Bump API patch number and header version number to 25 for this update.
  * Structurally change the specification so that multiple extensions are
    included in the +1.0+ git branch, and specifications will include or not
    include those extensions at build time based on options passed to the
    Makefile. See +doc/specs/vulkan/README.html+ and the ``Layers and
    Extensions'' section of the ``Vulkan Documentation and Extensions''
    document for more information on this change.
  * Register and publish new extensions in the single-branch form:
  ** +VK_NV_external_memory_capabilities+
  ** +VK_NV_external_memory+
  ** +VK_NV_external_memory_win32+
  ** +VK_NV_win32_keyed_mutex+
Github Issues:
  * Clarify description of GetInstanceProcAddr and GetDeviceProcAddr (public
    issue 212).
  * Add SPIR-V <<textures-operation-validation, instruction validation>> for
    single-sampled images (public issue 316).
  * Fix spelling of ``tesselation'' in a few places and note it as an
    exception to the American spelling rules convention (public issue
    327).
  * Fix Makefile to create output directory for ``styleguide''
    target (public issue 329).
  * Fix numerous minor issues with incorrectly tags on enumerant names and
    table titles (public issue 330).
  * Generate specversion.txt date in UTC time and RFC 2822 format
    (public issue 335).
  * Convert link to the SPIR-V Specification for
    flink:VkShaderModuleCreateInfo into an internal link to the normative
    reference (public issue 336).
  * Add ename:VK_ERROR_OUT_OF_MEMORY error code to
    flink:vkCreateDebugReportCallbackEXT (public issue 337).
Internal Issues:
  * Update style guide regarding use of code:NULL and dname:VK_NULL_HANDLE
    (internal issue 393).
  * Change the definition of latexmath:[$q$] in the
    <<textures-image-level-selection,texture image level selection>> section
    to be the index of the maximum defined level for the view, not the
    number of levels in the view (internal issue 406).
  * Allow developers to override dname:VK_DEFINE_NON_DISPATCHABLE_HANDLE
    with their own binary-compatible definition (internal issue 439).
  * Fix +vk_platform.h+ conditional logic causing compile failure with some
    Android compilers (internal issue 441).
  * Implement the single-branch model as described above (internal issue
    461).
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/85184f305afe0f2e9e99cc9525e8ce25c32e74e0
Vulkan API specifications 1.0.32 released
« Reply #8 on: November 01, 2016, 01:41:26 PM »
Change log for October 25, 2016 Vulkan 1.0.32 spec update:
  * Bump API patch number and header version number to 32 for this update.
Github Issues:
  * Add automatic visibility operations to the presentation engineE when
    doing a queue present in flink:vkAcquireNextImageKHR. Removed all
    references to MEMORY_READ that referenced WSI - they no longer make
    sense (some aspects of public issues 128, 131, 132, 261, and 298).
  * Document valid non-boolean +externsync+ attribute values for <param>
    tags in +vk.xml+ (public issue 265).
  * Add valid usage to slink:VkImageCreateInfo requiring that
    pname:arrayLayers be 1 for images of type ename:VK_IMAGE_TYPE_3D
    (public issue 319).
  * Add missing captions to figures in the <<textures,Image Operations>>
    chapter (public issue 334).
  * Clarify WSI interaction with exclusive sharing mode (public issue
    344).
  * Added explicit language clarifying the allowed queue usage of
    resources created with ename:VK_SHARING_MODE_CONCURRENT (public
    issue 386).
  * Require that the
    slink:VkDescriptorSetLayoutCreateInfo::pname:binding members of the
    pname:pBindings array passed to
    flink:vkDescriptorSetLayoutCreateInfo all be distinct (public issue
    391).
Internal Issues:
  * Remove empty validity blocks from +vk.xml+ and suppressed broken
    validity statements and added missing statements to explicit
    validity. Doesn't affect output, other than some statements
    appearing in another block now (internal issue 513).
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/368b08a7b2add6db489d0af766bd74854e1c87d4
Vulkan API specifications 1.0.34 released
« Reply #9 on: November 25, 2016, 05:51:30 PM »
Change log for November 18, 2016 Vulkan 1.0.34 spec update:
 * Bump API patch number and header version number to 34 for this update.
Github Issues:
  * Allow vkUpdateDescriptorSets overflow to skip empty bindings. Clarify
    that unused bindings have a descriptorCount of zero. Improve some valid
    usage for vkUpdateDescriptorSets (public issue 256).
  * Require that slink:VkImageSubresourceRange always define a non-empty
    range of the resource (public issue 303).
  * Added valid usage for slink:VkPresentInfoKHR on the layout of presented
    images (public issue 397).
Internal Issues:
  * Add dependency in src/spec/Makefile so specversion.txt is regenerated
    when needed (internal issue 462).
  * Shorten the table of contents in the single-page ref page HTML output.
    Still working on the PDF (internal issue 536).
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/08310a88df8c803ac916102e7a364fff912e3281
Vulkan API specifications 1.0.35 released
« Reply #10 on: November 27, 2016, 12:59:57 PM »
Change log for November 25, 2016 Vulkan 1.0.35 spec update:
  * Bump API patch number and header version number to 35 for this update.
Github Issues:
  * Document in the <<memory-device-hostaccess,Host Access>> section that
    mapping and unmapping does not invalidate or flush the mapped memory
    (public issues 27, 126).
  * Redefine the entire <<synchronization>> chapter in terms of consistent
    and well defined terminology, that's called out at the start of the
    chapter. This terminology is applied equally to all synchronization
    types, including subpass dependencies, submissions, and much of the
    implicit ordering stuff dotted around the spec. Key terms are laid out
    in the <<synchronization-dependencies,Execution and Memory
    Dependencies>> section at the top of the rewritten chapter (public
    issues 128, 131, 132, 217, 299, 300, 302, 306, 322, 346, 347, 371, 407).
  * Specify order of submission for batches in the
    <<vkQueueSubmit,vkQueueSubmit>> and
    <<vkQueueBindSparse,vkQueueBindSparse>> commands (public issue 371).
  * Add valid usage statements to each of the WSI extension sections
    indicating that the WSI-specific structure parameters must be valid, and
    remove automatically generated valid usage statements now covered by the
    manual sections (public issue 383).
  * Clarify render pass compatibility for flink:vkCmdExecuteCommands (public
    issue 390).
Internal Issues:
  * Update +vk.xml+ to make previously explicit valid usage statements for
    <<vkDebugReportMessageEXT,vkDebugReportMessageEXT>> implicit instead
    (internal issue 553).
  * Add valid usage statement for slink:VkCreateImageInfo preventing
    creation of 1D sparse images (internal issue 573).
  * Fix Python scripts to always read/write files in utf-8 encoding, and a
    logic error in reflib.py which could cause a fatal error for
    malstructured asciidoc (internal issues 578, 586).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/789549ff080dd8aece944b7c5261eb42f97b55c7
« Last Edit: November 27, 2016, 02:15:52 PM by JeGX »
Vulkan API specifications 1.0.37 released
« Reply #11 on: December 13, 2016, 06:14:26 PM »
Change log for December 10, 2016 Vulkan 1.0.37 spec update:
  * Bump API patch number and header version number to 37 for this update.
Github Issues:
  * Add usability guarantees on the values returned by
    flink:vkGetPhysicalDeviceSurfaceCapabilitiesKHR in the
    slink:VkSurfaceCapabilitiesKHR structure and by
    flink:vkGetPhysicalDeviceSurfaceFormatsKHR in the
    pname:pSurfaceFormatCount parameter (public issue 385).
  * Add elink:VkDebugReportObjectTypeEXT enumerants for new object types
    introduced by new extensions (public issue 408).
  * Add +VK_NVX_device_generated_commands+ etext:ACCESS bits and define how
    they are used (public issue 415).
  * Fix indentation for slink:VkDebugReportCallbackCreateInfoEXT member
    descriptions (public issue 419).
Internal Issues:
  * Expand requirements memory binding of non-sparse images and buffers from
    the <<resources-association,Resource Memory Association>> section into
    valid usage statements for all of the applicable API calls (internal
    issue 508).
  * Explicitly state that valid usage of flink:vkCreateImage requires that
    flink:vkGetPhysicalDeviceImageFormatProperties would return
    ename:VK_SUCCESS for the requested image configuration (internal issue
    598).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/8f014fa579ba050d9c5a3df2bdbca04107846c45
Vulkan API specifications 1.0.38 released
« Reply #12 on: December 19, 2016, 08:22:09 PM »
* Bump API patch number and header version number to 38 for this update.
Github Issues:
  * Make ename:VK_PIPELINE_STAGE_HOST_BIT invalid for all stage masks,
    except for flink:vkCmdWaitEvents (public issue 261).
Internal Issues:
  * Added validation language for flink:vkQueueBindSparse,
    slink:VkPresentInfoKHR, and slink:VkSubmitInfo, and a note to the
    <<synchronization-semaphores-waiting,Semaphore Waiting and Unsignaling>>
    section to clarify that semaphores must be signaled and waited on in a
    1:1 fashion (internal issue 546).
  * Modify valid usage for slink:VkBufferImageCopy to only require
    pname:bufferOffset to be a multiple of the image format's element size
    when the format is not depth/stencil (internal issue 594).
Other Issues:
  * Vulkan(R) is now a registered trademark symbol, and this is reflected in
    documents and copyright statements.
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/70b659d28d01a75209d27afbfd764d1ef0d1dcb3
Vulkan API specifications 1.0.39 released
« Reply #13 on: January 24, 2017, 07:21:40 PM »
Change log for January 23, 2017 Vulkan 1.0.39 spec update:
  * Bump API patch number and header version number to 39 for this update.
Github Issues:
  * Clarified that only accesses via the specified buffer/image subresource
    ranges are included in the access scopes (public issue 306).
  * Add missing valid usage statements for flink:vkCreateComputePipelines
    and flink:vkCreateGraphicsPipelines (public issue 427).
Internal Issues:
  * Add a Note to the <<invariance,Invariance>> appendix about a difference
    between OpenGL and Vulkan with regards to how primitives derived from
    offsets are handled (internal issue 355).
  * Add the +<<VK_KHR_get_physical_device_properties2>>+,
    +<<VK_KHR_maintenance1>>+, and +<<VK_KHR_shader_draw_parameters>>+
    extensions (internal issue 448).
  * Add the +<<VK_EXT_shader_subgroup_vote>>+ and
    +<<VK_EXT_shader_subgroup_ballot>>+ extensions (internal issue 449).
  * Update the texture level-of-detail equation in the
    <<textures-scale-factor,Scale Factor Operation>> section to better
    approximate the ellipse major and minor axes (internal issue 547).
  * Forbid non-explicitly allowed uses of interface decorations in the
    introduction to the <<interfaces,Shader Interfaces>> chapter (internal
    issue 607).
  * Replace use of MathJax with KaTeX, for improved load-time performance as
    well as avoiding the scrolling-and-scrolling behavior due to MathJax
    asynchronous rendering when loading at an anchor inside the spec. This
    change also requires moving to HTML5 output for the spec instead of
    XHTML, and there is a visible difference in that the chapter navigation
    index is now in a scrollable sidebar instead of at the top of the
    document. We may or may not retain the nav sidebar based on feedback
    (internal issue 613).
  * Improve consistency of markup and formatting in extension appendices
    (internal issue 631).
Other Issues:
  * Add explicit valid usage statements to slink:VkImageCopy requiring that
    the source and destination layer ranges be contained in their respective
    source and destination images.
  * Add valid usage language for swapchain of flink:vkAcquireNextImage. If
    the swapchain has been replaced, then it should not be passed to
  * Add a valid usage statement to flink:vkCreateImageView, that the image
    must have been created with an appropriate usage bit set.
  * Noted that slink:VkDisplayPresentInfoKHR is a valid extension of
    slink:VkPresentInfoKHR in the <<wsi_swapchain,WSI Swapchain>> section.
  * Update valid usage for flink:vkCmdSetViewport and flink:vkCmdSetScissor
    to account for the multiple viewport feature. If the feature is not
    enabled, the parameters for these functions have required values that
    are defined in the <<features-features-multiViewport,multiple
    viewports>> section of the spec but were not reflected in the valid
    usage text for these functions.
  * Add the +<<VK_EXT_swapchain_colorspace>>+ extension defining common
    color spaces.
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/ca4abe0d34ca8ed8410c65c177f8658da183576d
« Last Edit: February 13, 2017, 08:15:37 AM by JeGX »
Vulkan API specifications 1.0.40 released
« Reply #14 on: February 12, 2017, 10:17:38 PM »
Change log for February 10, 2017 Vulkan 1.0.40 spec update:
  * Bump API patch number and header version number to 40 for this update.
  * There is a major build change in this release. We are now using the
    Ruby-based ``asciidoctor'' implementation, rather than the Python-based
    ``asciidoc'' implementation, to process the specification. While the
    actual specification markup changes were minimal, this requires a new
    set of build tools and a very different installation process, especially
    because we now use an experimental direct-to-PDF backend for Asciidoctor
    instead of Docbook->dblatex->PDF. It is no longer possible to build the
    Specification using asciidoc. See doc/specs/vulkan/README.adoc
    for some guidance on installing the new toolchain components.
  * There are some minor rendering issues in the PDF output due to teething
    problems with the asciidoctor toolchain, especially with mathematical
    equations. We are aware of these and working on them.
Github Issues:
  * Updated sample code for the <<sparsememory-examples-basic,sparse
    resource binding example>> (public issue 97).
  * Modify line and point clipping behavior in the
    <<vertexpostproc-clipping, Primitive Clipping>> section to allow for
    pop-free behavior. The ability to check for which behavior is
    implemented may be added a future feature or extension (public issue
    113).
  * Unify the discussions of implicit ordering throughout the spec, in
    particular in the new sections <<drawing-primitive-order, Primitive
    Order>>, <<primrast-order, Rasterization Order>>, and
    <<synchronization-implicit, Implicit Synchronization Guarantees>>; the
    discussion of <<synchronization-submission-order, submission order>>;
    and references elsewhere to these sections (public issue 133).
  * Clarify \<\<descriptorsets-compatibility,Pipeline Layout Compatibility>>
    language and introduce the term ``identically defined'' (public issue
    164).
  * Add a dependency to the +VK_EXT_debug_marker+ extension that's needed to
    reuse the object type enum from +VK_EXT_debug_report+, and moves the
    definition of that enum into +VK_EXT_debug_report+ where it should be
    (public issue 409).
  * Remove redundant valid usage statement from slink:VkImageBlit (public
    issue 421).
  * Update GL_KHR_vulkan_glsl to allow the ternary operator to result in a
    specialization constant (public issue 424).
  * Fix valid usage for flink:VkPipelineShaderStageCreateInfo (public issue
    426).
  * Correct typo in New Objects list for <<VK_EXT_debug_report>> (public
    issue 447).
Internal Issues:
  * Moved to asciidoctor for spec builds (internal issue 121).
  * Update style guide to describe where to put new extensions-specific
    asciidoc files, and what to name them (internal issue 626).
  * Add src/spec/indexExt.py to autogenerate registry index entries linking
    into the 1.0-extensions specification, instead of maintaining the index
    manually. (internal issue 642).
  * Autogenerate extension dependencies and lists of all extensions and all
    KHR extensions from the "supported" attributes in +vk.xml+. Execute
    +make config/extDependency.sh+ from +doc/specs/vulkan+ when a supported
    extension is added to vk.xml, to regenerate the dependency script. The
    consequence is that specifying a single extension to the +makeExt+
    script will automatically enable all extensions it depends on as well,
    and that the +makeAllExts+ and +makeKHR+ scripts do not need to be
    updated when a new extension is supported (internal issue 648).
  * Put extension appendices all at the same asciidoc section level, so KHR
    WSI extensions show up in the HTML index (internal issue 648).
Other Issues:
  * Imbed images in the generated HTML specs instead of loading them from
    the images/ directory.
  * Fix missing EXT in extension name
    (ename:VK_EXT_SWAPCHAIN_COLOR_SPACE_EXTENSION_NAME).
  * Add new +VK_EXT_SMPTE_2086_metadata+ extension.
  * In the <<platformCreateSurface_xlib,Xlib Surface>> section of the
    +VK_KHR_xlib_surface+ specification, add language warning users that
    they always need to call code:XinitThreads.
  * Use the term "presentable image" (rather than "swapchain image")
    consistently in +VK_KHR_swapchain+ and related extensions, and add a
    glossary term defining it.
  * Relocate the valid usage for samples of
    flink:vkGetPhysicalDeviceSparseImageFormatProperties2KHR::pname:pFormatInfo
    to be below the flink:VkPhysicalDeviceSparseImageFormatInfo2KHR
    structure.
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/82e0f83d43f36c8c98c2aaed8da152480acb477b
« Last Edit: February 13, 2017, 08:15:12 AM by JeGX »
Vulkan API specifications 1.0.42 released
« Reply #15 on: February 27, 2017, 01:02:47 PM »
Change log for February 27, 2017 Vulkan 1.0.42 spec update:
  * Bump API patch number and header version number to 42 for this update
    (the first anniversary edition).
Github Issues:
  * Changed asciidoctor macros so cross-page links in the standalone
    reference pages function properly (public issue 462).
Internal Issues:
  * Clarified host visibility discussion for slink:VkMemoryType,
    flink:vkInvalidateMappedMemoryRanges, elink:VkAccessFlagBits, and the
    <<synchronization-framebuffer-regions,Framebuffer Region Dependencies>>
    section, removing duplicated information and adding a central definition
    in the access types section (internal issue 552).
  * Change description of
    slink:vkGetPhysicalDeviceSurfacePresentModesKHR::pname:pPresentModes to
    return an array of values, not structures (internal issue 699).
New Extensions:
  * Add a NOTE to the <<extensions,Layers & Extensions>> chapter describing
    the experimental status of `KHX` extensions.
  * Add new Khronos, Khronos Experimental, and vendor Vulkan extensions for
    release at GDC:
  ** VK_KHR_descriptor_update_template
  ** VK_KHR_push_descriptor
  ** VK_KHX_device_group
  ** VK_KHX_device_group_creation
  ** VK_KHX_external_memory
  ** VK_KHX_external_memory_capabilities
  ** VK_KHX_external_memory_fd
  ** VK_KHX_external_memory_win32
  ** VK_KHX_external_semaphore
  ** VK_KHX_external_semaphore_capabilities
  ** VK_KHX_external_semaphore_fd
  ** VK_KHX_external_semaphore_win32
  ** VK_KHX_multiview
  ** VK_KHX_win32_keyed_mutex
  ** VK_EXT_discard_rectangles
  ** VK_MVK_ios_surface
  ** VK_MVK_macos_surface
  ** VK_NVX_multiview_per_view_attributes
  ** VK_NV_clip_space_w_scaling
  ** VK_NV_geometry_shader_passthrough
  ** VK_NV_sample_mask_override_coverage
  ** VK_NV_viewport_array2
  ** VK_NV_viewport_swizzle
  * Add new GLSL vendor extensions to support new builtin variables:
  ** GL_EXT_device_group
  ** GL_EXT_multiview
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/fd0e4c3b67dd07877eae97965e863f2945104d9e
Vulkan API specifications 1.0.43 released
« Reply #16 on: March 11, 2017, 08:36:01 PM »
Change log for March 10, 2017 Vulkan 1.0.43 spec update:
  * Bump API patch number and header version number to 43 for this update.
Github Issues:
  * Make clearer that color write mask is applied regardless of whether
    blending is enabled, by referring to the
    <<framebuffer-color-write-mask,Color Write Mask>> section (public issue
    241).
  * Fix public issue 414:
  ** Added two new command buffer states (invalid, pending), and an explicit
     "command buffer lifecycle" section to explain them.
  ** Replaced "pending execution" with "in the pending state".
  ** Replaced a bunch of "this will invalidate the command buffer" language
     with "this will move the command buffer to the invalid state", and added
     validation language for what state those command buffers should be in.
  ** Added additional validation language about what state a command buffer
     should be in for various commands that affect it.
  ** Added invalidation language to destroy commands in the lifetimes section
     of fundamentals.
  ** Added command buffers to list of objects which must not be deleted
     whilst a (primary) command buffer is in the recording or pending state.
  * Update `GL_KHR_vulkan_glsl` extension to allow anonymous push constant
    blocks (public issue 428).
Internal Issues:
  * Document rules about extension interactions in the style guide (internal
    issue 579).
  * Require ename:VK_PRESENT_MODE_MAILBOX_KHR support in queries of surfaces
    created with flink:vkCreateWaylandSurfaceKHR using the
    VK_KHR_wayland_surface extension (internal issue 666).
  * Remove Valid Usage constraints for flink:vkAllocateDescriptorSets when
    the `VK_KHR_maintainance1` extension is present (internal issue 686).
  * Remove undocumented KHX-variants of vkGetPhysicalDeviceProperties2KHR
    and vkGetPhysicalDeviceImageFormatProperties2KHR from the
    <<VK_KHX_external_memory_capabilities>> and
    <<VK_KHX_external_semaphore_capabilities>> extensions.
New Extensions:
  * `VK_EXT_hdr_metadata`
  * `VK_GOOGLE_display_timing`
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/3e4bee3d115e4eb58cb6559af27ed769eccde393
« Last Edit: March 21, 2017, 03:14:56 PM by JeGX »
Vulkan API specifications 1.0.44 released
« Reply #17 on: March 20, 2017, 11:09:39 PM »
Change log for March 17, 2017 Vulkan 1.0.44 spec update:
  * Bump API patch number and header version number to 44 for this update.
Github Issues:
  * Fix description of <<features-extentperimagetype, Allowed Extent Values
    Based On Image Type>> (public issue 290).
  * Better specify VK_DEVICE_LOST behavior around flink:vkQueueSubmit,
    flink:vkWaitForFences, and flink:vkGetFenceStatus (public issue 423).
  * Clarify definition of flink:vkGetQueryPoolResults::pname:queryCount
    (public issue 441).
  * Simplify and clean up normative language. Remove shall and replace
    recommend and variants with should wherever possible (public issue 448).
  * Fix all dangling internal cross-references in the 1.0-extensions
    specification, and add scripts/checkXrefs to find these in the future
    (public issue 456).
  * Reverse order of ChangeLog.txt entries so the most recent version is
    documented first (public issue 463)
  * Removes "become invalid" which clashes with invalid state for command
    buffers. (public issue 467)
  * Disallowed pending state in spec text for vkResetCommandBuffer, matching
    valid usage (public issue 468)
  * Removes sentence describing invalid state "like initial state". (public
    issue 469)
  * Disallows begin command buffer from resetting command buffers in the
    "recording" state. (public issue 470)
  * Removes mention of state from description of
    VK_COMMAND_POOL_CREATE_RESET_COMMAND_BUFFER_BIT (public issue 471)
  * Removed extra valid usage statement in VkSubmitInfo (public issue 472)
Internal Issues:
  * Clarify description of the pname:imageLayout member of
    sname:VkDescriptorImageInfo.
  * Fix typos where etext:VK_VIEW_TYPE* was used instead of
    etext:VK_IMAGE_VIEW_TYPE.
  * Removed the <<VK_KHR_display>> and <<VK_KHR_display_swapchain>> example
    code from the specification and noted it has been moved to the Vulkan
    SDK cube demo (internal issue 179).
  * Reorder VkExternalMemoryHandleTypeFlagBitsNV description (internal issue
    480).
  * Clarify than an implementation is
    <<fundamentals-validusage-flags,permitted to return 'undefined' bit
    flags>> in a bitfield (internal issue 640).
  * Break Valid Usage statements describing unrelated parameters into
    separate statements, and add a style guide entry to follow this approach
    (internal issue 685).
  * Move valid usage statement for slink:VkImageCreateInfo from spec body to
    the explicit valid usage block (internal issue 693).
  * Fix typos in the descriptions of slink:VkDisplaySurfaceCreateInfoKHR,
    flink:vkCreateDisplayModeKHR, and
    flink:vkGetDisplayPlaneSupportedDisplaysKHR in the <<display,Presenting
    Directly to Display Devices>> section (internal issue 698, 704, 716).
  * Clarified that mandatory depth/stencil formats are only a requirement
    for 2D images (internal issue 719).
  * Clarify that variables decorated with DeviceIndex/ViewIndex must be in
    the Input storage class (internal issue 733).
  * Work around generator script problem with removal of Unicode literals
    from Python 3.0-3.2 using `future` package (internal issue 737).
  * Remove nonexistent structure type enums from vk.xml (internal issue
    738).
  * Fix validextensionstructs attributes for structures in the pname:pNext
    chain for VkPresentInfoKHR, fixing implicit valid usage statements for
    those structures (internal issue 740).
New Extensions: ---
Source: https://github.com/KhronosGroup/Vulkan-Docs/commit/43f1fd5550cac5547cf3421ad0783f46a6e64aa2
« Last Edit: March 21, 2017, 03:14:45 PM by JeGX »
Vulkan API specifications 1.0.45 released
« Reply #18 on: March 25, 2017, 07:54:28 PM »
Change log for March 24, 2017 Vulkan 1.0.45 spec update:
  * Bump API patch number and header version number to 45 for this update.
Github Issues:
  * Defined the lifetime of the memory pointed to by
    slink:VkDisplayPropertiesKHR::pname:displayName to be equal to that of
    its associated display handle (public issue 460).
  * Correct several cases where the sparse memory feature name
    pname:residencyNonResidentStrict was written as
    pname:sparseResidencyNonResidentStrict (public issue 475).
Internal Issues:
  * Fix ptext:pNext member of slink:VkPhysicalDeviceGroupPropertiesKHX to be
    a non-const pointer. Properties structures return values, so the chain
    should be non-const.
  * Clarify definition of memory aliasing to consistently use the terms
    "linear" and "non-linear" when referring to resources, and define what
    those terms mean.
  * Modified XML schema and implicit validity scripts to generate language
    for all ptext:pNext values in a ptext:pNext chain instead of just the
    top level struct, and made `noautovalidity` functional for ptext:sType
    and ptext:pNext (internal issue 535).
  * Add more detail for BT2020 and scRGB color spaces in
    `VK_EXT_swapchain_colorspace` extension (internal issue 632).
  * Add naming rules for Extension Structure Names (structures added to the
    ptext:pNext chain of a base structure) to the style guide (internal
    issue 706).
  * Define the glossary term "ptext:pNext chain", and use it consistently in
    the spec (internal issue 744).
New Extensions:
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/e8cbffbd2548d26915f7a52bbff1204d7407fd09
« Last Edit: March 27, 2017, 01:19:42 PM by JeGX »
Vulkan API specifications 1.0.46 released
« Reply #19 on: April 04, 2017, 04:48:05 PM »
* Bump API patch number and header version number to 46 for this update.
Github Issues:
  * Add language to the <<fundamentals-validusage-enums, Valid Usage for
    Enumerated Types>> section allowing values to be returned from Vulkan
    that are not present in extensions explicitly enabled by the
    application, similar to existing language for bit flags in the
    <<fundamentals-validusage-flags, Valid Usage for Flags>> section (public
    issue 442).
  * *Important*: run `gem update --pre asciidoctor-pdf` before trying to
    build this version of the spec - 1.5.0.alpha15 is required for this
    change. Removes the monkey patch currently used to draw valid usage
    blocks across multiple pages which had numerous issues. A fixed version
    was incorporated into Asciidoctor-PDF for the latest release, so the
    monkey patch or any variant thereof is no longer required (public issue
    465).
Internal Issues:
  * Add ename:VK_DEBUG_REPORT_OBJECT_TYPE_DESCRIPTOR_UPDATE_TEMPLATE_KHR_EXT
    to `VK_EXT_debug_report` extension
    slink:VkPhysicalDeviceDiscardRectanglePropertiesEXT to be a non-const
    pointer. Properties structures return values, so the chain should be
    non-const.
  * Explicitly remove gl_NumSamples from the `GL_KHR_vulkan_glsl` extension,
    against 1.0 (internal issue 612).
  * Add Valid Usage statements requiring that each structure type valid in a
    ptext:pNext chain must: not appear more than once in a chain (internal
    issue 752).
  * Use ename:VK_USE_PLATFORM_WIN32_KHX in the
    `VK_KHX_external_memory_win32` extension, rather than etext:_KHR
    (internal issue 754).
New Extensions:
  * `VK_KHR_incremental_present`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/f985a50c1f0b6f37c706db32d70da85bc1e2d78f
