Author Topic: What is 802.11ax WiFi, and will it really deliver 10Gbps?  (Read 4329 times)
gyg
  • Jr. Member
« on: April 29, 2015, 07:44:02 PM »
"... if you thought that your new 802.11ac router’s maximum speed of 1,300Mbps was already fast, think again. With 802.11ac fully certified and out the door, the Wi-Fi Alliance has started looking at its successor, 802.11ax — and it looks pretty enticing. While you may have a hard time getting more than 400Mbps to your smartphone via 802.11ac, 802.11ax should deliver real world speeds above 2Gbps. And in a lab-based trial of technology similar to 802.11ax, Huawei recently hit a max speed of 10.53Gbps, or around 1.4 gigabytes of data transfer per second. Clearly, 802.11ax is going to be fast. But what is it exactly?"
http://www.extremetech.com/computing/184685-what-is-802-11ax-wifi-and-do-you-really-need-a-10gbps-connection-to-your-laptop
gmx048
Re: What is 802.11ax WiFi, and will it really deliver 10Gbps?
« Reply #1 on: April 14, 2018, 09:18:41 PM »
Is that certain ip based router. Because I am using comcast router and it's login url is 10.0.0.0.1. Will that thing also work for my router ?
https://10-0-0-0-1.org
« Last Edit: April 15, 2018, 06:47:55 AM by gmx048 »
machrit112
« Reply #2 on: August 19, 2018, 03:29:07 AM »
I am using Apple Airport Router using login ip 10.0.1.1. Will the same thing will work my router ?
