Author Topic: Gputest 0.7.0 does not recognize SLI  (Read 4154 times)
jasjuang
« on: April 13, 2015, 03:07:38 AM »
I ran all the stress tests in Gputest 0.7.0 downloaded from here http://www.geeks3d.com/20140304/gputest-0-7-0-opengl-benchmark-win-linux-osx-new-fp64-opengl-4-test-and-online-gpu-database/, and whether I enable or disable SLI the fps is always the same.
But what's funny is I tested with a stand alone furmark from http://www.geeks3d.com/20101209/tips-how-to-enable-sli-and-crossfire-support-for-opengl-applications/. I did see a performance boost with SLI enabled. So does that means there is something wrong with Gputest 0.7.0 that prevents it from recognizing SLI?
Thanks
Re: Gputest 0.7.0 does not recognize SLI
« Reply #1 on: April 14, 2015, 10:47:13 AM »
I will release a major update of GpuTest shortly, and I'll check the SLI support at this moment.
