Author Topic: FreeType-GL plugin (TTF and OTF)  (Read 5197 times)
« on: November 03, 2014, 04:17:00 PM »
One of the coolest features of GLSL Hacker 0.8.0 is the support of FreeType GL via a dedicated plugin. Thanks to this new plugin, GLSL Hacker can now load any TTF (True Type Font) or OTF (Open Type Font) file. I also added a small Lua lib (gx_font.lua in the libs/lua/ folder of glsl hacker) to make things easier.
INIT script:
-- Load an otf file:
font = ftgl_load_font(demo_dir .. "data/BebasNeue.otf", 30)
FRAME script:
ftgl_begin(font)
ftgl_print(font, 10, 60, 1.0, 1.0, 0, 1.0, "GLSL Hacker rocks!")
ftgl_end(font)
Demos are available in the host_api/freetype-gl/ folder of the code sample pack v2.25.0.
The plugin is available for all platforms (Windows, OSX and Linux).
« Last Edit: November 03, 2014, 04:27:01 PM by JeGX »
