Author Topic: GLSL Hacker 0.6.4.3  (Read 3541 times)
GLSL Hacker 0.6.4.3
« on: May 28, 2014, 02:45:59 PM »
A new dev version of GLSL Hacker is ready but only for Windows.
You can download it from this page:
http://www.geeks3d.com/glslhacker/download.php
Changelog:
Version 0.6.4.3 - 2014.05.28
* fixed a bug in gh_mesh.set_vertices_color() in Lua.
+ added set_vertices_color() to gh_mesh in Python.
+ added mouse_get_wheel_delta() to gh_input lib.
+ added new keyboard keys support (shift, ctrl, alt and windows key).
+ added keyboard_codes.lua in GLSL Hacker Lua libs folder.
+ added FreeImage plugin with floating point (96 and 128-bit) support.
+ added set_current_image_codec_name() to gh_texture module.
GLSL Hacker 0.6.4.3 adds a new image loader plugin based on FreeImage. To use this plugin, just specify it before loading a texture:
gh_texture.set_current_image_codec_name("FreeImage")
tex = gh_texture.create_from_file(...)
If the FreeImage plugin is not present, GLSL Hacker uses the built-in image loader.
