Author Topic: GLSL Hacker 0.6.3.19 released  (Read 4916 times)
Re: GLSL Hacker 0.6.3.19 released
« Reply #1 on: May 13, 2014, 07:55:18 PM »
Crash on exit with AMD HD 6320 / Catalyst 14.4
18004B230 ; DWORD __stdcall StartAddress(LPVOID)
18004B230 StartAddress    proc near               ; DATA XREF: gxl3d::TcpServer::run(ushort)+1F7
18004B230                                         ; .pdata:00000001800F0F20 ...
18004B256                 mov     r8, [rcx+50h] ; exception offset
RUNTIME_FUNCTION <rva ?accept_connection@SocketCore@gxl3d@@UEAAPEAVSocket@2@PEAV32@@Z,\ ; gxl3d::SocketCore::accept_connection(gxl3d::Socket *)
.pdata:00000001800F0F20                                   rva StartAddress, rva stru_1800BD55C>
« Reply #2 on: May 14, 2014, 09:30:43 AM »
Stefan, could you try to start GLSL Hacker without the TCP/IP server (used for remote live coding)?
To disable the tcpi/ip server, just add /disable_tcpip_server to the command line:
> GLSLHacker.exe  /disable_tcpip_server
« Reply #3 on: May 14, 2014, 04:18:07 PM »
OK, that works
