Author Topic: only ~50 fps in ShaderToyMark before bench  (Read 16965 times)
  • Full Member
« on: July 19, 2013, 07:39:11 PM »
Hi! :)
Now:
I got ~50 fps (stutter randomly) before bench in STM running XP x86 SP3 and GTX 480 (306.81WHQL) but I got normal performances in NV demos OpenGL (Adrianne, Froggy, Luna...).
Before driver clean:
I got normal performance (extreme framerate without any stutter) bench but I got (too) slow in same NV demos running same OS with 320.49WHQL.
Any help...
NOTE: I got normal performances in STM and NV demos running Win 7 x64 SP1 and 320.49WHQL.
But notice: please should response - here
« Last Edit: July 19, 2013, 07:41:37 PM by nuninho1980 »
  • Full Member
Re: only ~50 fps in ShaderToyMark before bench
« Reply #1 on: August 08, 2013, 04:03:03 PM »
Bump - PLEASE should response!
  • Full Member
« Reply #2 on: August 11, 2013, 12:38:43 PM »
PLEASE RESPONSE!!
  • Full Member
« Reply #3 on: September 13, 2013, 09:58:43 PM »
HEEEEEEEEEEEEEEEEEELLLLLLP!!!!!!!!!!!! Due to too time!!!  ??? ???
« Reply #4 on: September 14, 2013, 09:16:55 AM »
With latest R326.98, ShaderToyMark runs fine on Win7/Win8 with correct FPS.
Sorry but I don't have anymore a WinXP testbed so I can't tell you if  ShaderToyMark still works or not correctly with XP.
Does your GTX 480 work fine with FurMark (correct FPS, GPU temperature)? If yes, forget your issues with ShaderToyMark.
  • Full Member
« Reply #5 on: September 16, 2013, 06:10:53 PM »
Yes, STM and FurMark work correctly for framerate and temperature despite abnormal performance (STM only) because the framerate by and temperature by Geeks is same number to monitor eVGA Precision.
I can improve performance from 80-90 to 200 fps in STM before bench but "200 fps" isn't normal (due to only max 60% GPU usage and to 26% CPU i5-2500K usage) when the cursor mouse is from stopping to fastly moving, running XP with GF 306.81WHQL driver.
Please, should install XP.
Can you detect any problem found?
  • Full Member
« Reply #6 on: April 09, 2014, 01:00:45 AM »
I have changed from "multiple display performance" to "single display performance" in NVCP and... I can improve performance to insane framerate in STM!!! :D
EDIT: But... Close NVCP. Re-start STM and I got ~90 fps. I'm weird. :S
« Last Edit: April 09, 2014, 01:19:40 AM by nuninho1980 »
  • Full Member
« Reply #7 on: January 12, 2016, 01:20:00 PM »
After upgrade CPU from i5-2500K to i7-4790K...
Win 7 x64 SP1: I got ~2000 fps..., ~1300..., ~1500..., ~1950..., before start benchmark. When I moving mouse, from ~1300 to ~1900 fps.
Win 10 x64: ~4000 fps..., ~150..., ~130...(do not press start benchmark). When I'm moving mouse, from ~150 to ~250 fps.
Also on Windows XP.
Can you fix this issue?
« Last Edit: January 12, 2016, 08:33:37 PM by nuninho1980 »
  • Full Member
« Reply #8 on: January 25, 2016, 09:53:06 PM »
Can fix this issue running your OS as Win 7, 8.x or 10?
« Reply #9 on: January 28, 2016, 05:20:48 PM »
Shadertoymark is coded with the very first version of GeeXLab which is stopped since 3 years.  Then I can not fix current issues.
But I planned to code a new shadertoymark with some recent shaders...
