Author Topic: GLSL Hacker command line parameters  (Read 5334 times)
« on: May 16, 2013, 06:48:56 AM »
Here are the main command line parameters included in GLSL Hacker:
  • /fullscreen
        forces fullscreen mode.
  • /demofile="filename"
        specifies the absolute path to the demo file.
  • /benchmark_duration_ms=<n>
        specifies the duration of the demo/benchmark in milliseconds.
  • /benchmark_log_score
        writes benchmark results in the benchmarl log file (CSV file).
  • /benchmark_display_score_box
        displays the score box at the end of the benchmark.
  • /disable_opengl_support_check
        disables the check of the OpenGL version done at the beginning of a demo.
  • /noload_plugin_opencl
        disables the loading of the OpenCL plugin.
  • /noload_plugin_python27
        disables the loading of the Python 2.7 plugin.
  • /glinfo
        writes OpenGL complete information (all OpenGL extensions) in the log file.
  • /vbo_usage=<usage>
        forces vertex buffer usage: GL_STATIC_DRAW, GL_STATIC_READ, GL_DYNAMIC_DRAW, GL_DYNAMIC_READ, GL_STREAM_DRAW, GL_STREAM_READ.
  • /ibo_usage=<usage>
        forces index buffer usage: GL_STATIC_DRAW, GL_STATIC_READ, GL_DYNAMIC_DRAW, GL_DYNAMIC_READ, GL_STREAM_DRAW, GL_STREAM_READ.
Example:
GLSLHacker.exe /demofile="C:/The/Path To/The/Demo.xml" /vbo_usage=GL_STATIC_DRAW /benchmark_duration_ms=5000 /benchmark_display_score_box
