Author Topic: AMD Catalyst™ 13.3 Beta 2 Driver  (Read 5284 times)
« on: March 15, 2013, 10:47:01 PM »
Feature Highlights of the AMD Catalyst™ 13.3 Beta Driver for Windows®
    Improve performance in Sim City 5 up to 16 percent
    Improves performance in Far Cry 3 up to 5 percent
    Improves latency performance issues seen in Tomb Raider and Hitman Absolution
    Resolves slight corruption seen in Tomb Raider with TressFX enabled for CrossFire and single GPU configurations
also 9 new OpenGL extensions, mostly OpenGL 4.3
Re: AMD Catalyst™ 13.3 Beta 2 Driver
« Reply #1 on: March 20, 2013, 09:17:32 PM »
Feature Highlights of the AMD Catalyst™ 13.3 Beta3 Driver for Windows®
    Resolves OpenGL application issues seen with the AMD Catalyst 13.3 Beta2 driver
This "update" removes the new extensions.
You can thank the developer here:
https://twitter.com/CatalystCreator/status/314115029412765697
You can still uses this old workaround (with newer versions)
How to run OpenGL programs broken by ATI Catalyst 7.12+
