Author Topic: AMD Radeon™ HD 7900 Series Graphics Real-Time Demos  (Read 6182 times)
« on: January 27, 2012, 06:45:22 PM »
The Leo demo showcases a real-time, DirectX® 11 based lighting pipeline that is designed to allow for rendering scenes made of arbitrarily complex materials (including transparencies), multiple lighting models, and minimal restrictions on the number of lights that can be used -- all while supporting hardware MSAA and efficient memory usage.
Specifically, this demo uses DirectCompute to cull and manage lights in a scene. The end result is a per-pixel or per-tile list of lights that forward-render based shaders use for lighting each pixel. This technique also allows for adding one bounce global illumination effects by spawning virtual point light sources where light strikes a surface. Finally, the lighting in this demo is physically based in that it is fully HDR and the material and reflection models take advantage of the ALU power of the AMD Radeon HD 7900 GPU to calculate physically accurate light and surface interactions (multiple BRDF equations, realistic use of index of refraction, absorption based on wavelength for metals, etc).
About 4 fps with ATI Cedar  :P
Re: AMD Radeon™ HD 7900 Series Graphics Real-Time Demos
« Reply #1 on: January 28, 2012, 03:15:46 PM »
Hi-res pictures are available here: http://www.geeks3d.com/forums/index.php/topic,2459.0.html
Around 40 FPS on HD 6970 CF  ;D
« Reply #2 on: January 29, 2012, 09:01:30 AM »
NVIDIA users who get a black screen, can "enjoy" the demo in wireframe mode by hitting ALT+W.
Also: if you press ESC, a menu reveals a planned update with an "educational mode".
