Author Topic: Apple OpenCL RayTraced Quaternion Julia-Set Example v1.6  (Read 6173 times)
« on: October 02, 2011, 07:15:29 PM »
Last Revision:
Version 1.6, 2011-09-26
remove usage of make_float3 which is not supported by spec.
Updated Readme file to indicate that this demo will only work on Lion and onwards as it uses float3 vector data type.
The timestamp of the kernel file is March 2010  ??? , however this version runs faster in GPUCapsViewer
ljbade
  • Jr. Member
Re: Apple OpenCL RayTraced Quaternion Julia-Set Example v1.6
« Reply #1 on: October 03, 2011, 03:19:26 PM »
How did you get it to work in caps viewer?
« Reply #2 on: October 03, 2011, 03:45:48 PM »
Replace C:\Program Files (x86)\Geeks3D\GPU_Caps_Viewer_v1.14.3\media\qjulia_kernel.cl
