Author Topic: Mac OS X - Offline Compilation Using the OpenCL Compiler  (Read 5577 times)
« on: August 30, 2011, 09:58:42 PM »
Last Revision:
Version 1.0, 2011-08-23
Demonstrates using the OpenCL offline compiler to produce and utilize bitcode for CPU and GPU devices.
Build Requirements:
Xcode 4.0 or later, Mac OS X v10.7 or later
Runtime Requirements:
This sample demonstrates how developers can utilize the OpenCL offline compiler to transform their human-readable OpenCL source files into shippable bitcode. It includes an example Makefile that demonstrates how to invoke the compiler, and a self-contained OpenCL program that shows how to build a program from the generated bitcode. The sample covers the case of using bitcode on 64 and 32 bit CPU devices, as well as 32 bit GPU devices.
ljbade
  • Jr. Member
Re: Mac OS X - Offline Compilation Using the OpenCL Compiler
« Reply #1 on: August 30, 2011, 11:14:15 PM »
I wonder how they handle the different GPU targets? Like NVIDIA, AMD, and the various chip generations that Macs have shipped with over the years.
I wonder if it only compiles it to pseudo-assembly so that it can still recompile to the target chip at run time.
