Author Topic: HWiNFO32 v3.70 Released  (Read 4015 times)
« on: February 15, 2011, 06:23:50 AM »
Changes in HWiNFO32 v3.70 - Released on: Feb-14-2011:
    * Enhanced support of AMD Family 12h and 14h (APU).
    * Added new SSD SMART attributes.
    * Enhanced sensor monitoring on ASUS P8Q67 series.
    * Added reporting of Number of OC Bins and OC Extra Voltage for Sandy Bridge.
    * Added possibility to hide sensor values.
    * Reduced DPC latency during DELL EC sensor monitoring.
    * Improved battery status reporting in sensors on some machines.
    * Added AMD RADEON HD 6870M and RADEON HD 6970M branding.
    * Changed sensor log CSV format for better post-processing.
    * Enhanced sensor monitoring on Alienware M17x-R3.
    * Enhanced COMPAL EC sensor monitoring on some machines.
    * Added support of ITE IT8772F LPC/hardware monitor.
    * Enhanced sensor monitoring on Foxconn H67S.
    * Enhanced sensor monitoring on MSI GX720.
    * Improved support of ATI Northern Islands I2C.
    * Enhanced sensor monitoring on MSI MS-7672, MS-7673, MS-7678, MS-7681.
    * Added "Sensor-only" option to run in sensor monitoring mode only.
    * Enhanced sensor monitoring on Biostar TP67 and TH67 series.
    * Fixed GPU memory size reporting on GF108.
    * Added reporting of Intel 6-series PCH revision (B2, B3).
    * Improved HDA codec detection, fixed potential audio issues during scan.
    * Improved startup speed.
    * Enhanced sensor monitoring on GIGABYTE P65A series.
    * Enhanced sensor monitoring on Intel DP67, DH67, DH61, DQ67, DB65 series.
    * Updated reporting of memory module max speed in case XMP or EPP is supported.
