Please login or register.
Author Topic: NVIDIA CUDA 5 Preview Release Now Available  (Read 1386 times)
« on: May 17, 2012, 07:26:08 AM »
The CUDA 5 Preview release is now available to you via the CUDA Registered Developer program, find out more about the CUDA 5 Toolkit,
To download, we recommend and invite you to use the new CUDA Registered Developer experience on www.developer.nvidia.com/cuda
CUDA 5 introduces several new tools and features that make it easier than ever to add GPU acceleration to your applications.
New Nsight, Eclipse Edition helps you explore the power of GPU computing with the productivity of Eclipse on Linux and MacOS
    •  Develop, debug, and profile your GPU application all within a familiar Eclipse-based IDE
    •  Integrated expert analysis system provides automated performance analysis
       and step-by-step guidance to fix performance bottlenecks in the code
    •  Easily port CPU loops to CUDA kernels with automatic code refactoring
    •  Semantic highlighting of CUDA code makes it easy to differentiate GPU Code from
       CPU code
    •  Integrated CUDA code samples makes it quick and easy to get started
    •  Generate code faster with CUDA aware auto code completion and inline help
GPU callable libraries now possible with GPU Library Object Linking
    •  Compile independent sources to GPU object files and link together into a larger
       application
    •  Design plug-in APIs that allow developers to extend the functionality of your kernels
    •  Efficient and familiar process for developing large GPU applications
    •  Enables 3rd party ecosystem for GPU callable libraries
GPUDirect RDMA provides fastest possible communication between GPUs and other PCI-E devices
    •  Direct memory access (DMA) supported between NIC and GPU without the need for
       CPU-side data buffering
    •  Significantly improved MPISendRecv efficiency between GPU and other nodes in a
       network
    •  Eliminates CPU bandwidth and latency bottlenecks
    •  Works with variety of 3rd party network and storage devices
Dynamic Parallelism enables programmers to easily accelerate parallel nested loops on the new Kepler GK110 GPUs
    •  Developers can easily spawn new parallel work from within GPU code
    •  Minimizes the back and forth between the CPU and GPU
    •  Enables GPU acceleration for a broader set of popular algorithms, including adaptive
       mesh refinement used in aerospace and automotive computational fluid
       dynamics (CFD) simulations
    •  Supported natively on Kepler II architecture GPUs, preview programming guide and
       whitepaper available today
Logged
